RT809H ISP programming
  • ajbernasko
    • Mar 2022
    • 229
    • ghana
    Hello, Please I need a general knowledge in ISP programming for the RT809h. For instance an 8 pin bios chip, which one is the DO, CLK, CMD VCCQ of which I know pin 4 GND and PIN 8 is the VCC.
    1.
    2.
    3.
    4. GND
    5.
    6.
    7.
    8. VCC
    Please help me. Thank you
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: RT809H ISP programming
    Google RT809h ISP pin out.
    • ajbernasko
      • Mar 2022
      • 229
      • ghana
      that's good clue. Thank you
      • stylius
        RT809H ISP programming for laptop bios.
        by stylius
        Hello. I need some info. I have very good programer CHIPProg-481, fast and good programmer, but now I want read and modifi laptop bios dump without desoldering it. So want buy new programmer like RT809H for ISP programming for laptop bios. It is good for isp programing? or you recoment other?
        02-17-2023, 04:44 AM
      • ferah831208
        rt809h programming it8586 error
        by ferah831208
        i've been stucked several weeks trying to flash an it8586 from lenovo using rt809h, i've done intensive search over the internet and no results, i have the it8xxx interface adaptor and cables, i tried with it8586 directly sokdered in adaptor, i got it from a different motherboard to the one i was going to use, first time i read it succesfully 3 or 4 times only for testing, i wrote the new kbc firmware for nm-a181 and verified ok and then the trouble begun. everytime i read the chip is not recognized, i tried many times, unplugged programmer restar windows,updated rt809h with latest version december...
        12-10-2019, 10:32 AM
      • araxnido
        Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
        by araxnido
        Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
        When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
        06-10-2025, 09:26 PM
      • ferah831208
        help with rt809h for IT85xx series programming
        by ferah831208
        Hallo anyone has a wiring diagram of pins used in RT809 universal programmer for programming IT85xx series, i know there is an adaptor for this PEB-1 extension board for ITE series but where i live is not easy to purchase it,and i can't find any diagrams, i know from documents i found online i need to wire PD0-PD7 pins, Busy, STB,AFD,Init,Slin, KSI4 and KSI5 pins also to IT, but don't know to wuch of the RT809h programmer pins, I'm stucked,plz help
        08-30-2019, 02:15 PM
      • zesko
        MP2886A programming
        by zesko
        I have a board with a dead pwm on mp2886a. I order the chip without thinking about programming, and now I just realize my mistake.
        Someone know if it's 100% needed to program the chip ? And if so, how to program it ? I see some dedicated board and software but, software is a bit tricky to me, the bad part of the job...
        p.s : with the dead pwm chip, the GPU work fine when I disconnect the shorted pwm (6), with the new chip Pgood is 0 and the gpu doesn't start, so I guess it need to be programmed, or it's fake chip..
        p.s 2 : Sorry for my...
        07-28-2025, 02:07 PM
