Screen flickers after a while - Image attached
  • IamPritesh
    • Aug 2017
    • 354
    • India
    Model Name: Lenovo G570
    Issue : Screen flickers after a while randomly and stays like that until I restart the pc
    Action taken - replaced screen with a known good one .. still same issue. it could happen as soon as you boot or after an hour or so. One some days it just works fine the entire day.
    observation : works fine on external monitor
    also if I connect the external monitor while the screen is flickering , the laptop screen immediately reverts back to normal
    I am not what exactly could be wrong..
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • speedtime07
    i life zed air cx5 no image on screen
    by speedtime07
    hi everyone ,
    There is an image on the external computer screen ,
    flexi cable test ok - screen test ok -
    What alternative should I look for?
    thank you for your support​
    04-10-2025, 06:24 AM
  • plyanthony
    Razer Blade 15 no external display with attached screen disconnected from motherboard
    by plyanthony
    Computer in question : Razer Blade 15 2020 Base Model
    Model# RZ09-03286E22
    BIOS CHIP: WINBOND W25Q128BV
    What I'm trying to accomplish:
    I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
    What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
    W/Stock BIOS - 1.06:
    Disconnect the...
    02-01-2023, 09:35 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
