Help identifying a chip on HP Omen motherboard
  • apache23
    • 42
    • united states
    Need help identifying the chip in the pic so I can order one. It looks to have "3D" and "U5 or maybe Q5" printed on it. I went on a couple sites to try and find it, but there are too many and I don't really know how to find it. I think it's a mosfet? of some kind. With some help on another site, I ordered 3 BC856 transistors as we thought this was the right part. But as you see in the 2nd pic, it's a little too big. Any help would be appreciated! Btw, this is near the battery connection terminals on an HP Omen 15 at location Q205.
    • 21980
    Re: Help identifying a chip on HP Omen motherboard
    Whats the motherboard part number,have you checked for an available schematic .
    • R_J
      • 9607
      This might help getting the right package, it is smaller that sot23-3 so maybe Sc-70 or SC-85
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        As they have already said, without knowing the model or card or notebook it is not easy to identify the part. All the components that
        they start with Q, usually they are transistors but not always
        With 3D the most common component is MMBTA44
        • apache23
          • 42
          • united states
          Sorry for the delay, been very busy. The mobo part# is 812012-001 and I've looked literally for hours for a schematic. I even started a membership with Scribd and nothing. Some other mobo part #'s with the same components are :808333-001, 812013-001 and 812014-001. Thanks for the help!
          • apache23
            • 42
            • united states
            Thanks, I will check this out ASAP!
            • apache23
              • 42
              • united states
              Sorry for that, the model of the laptop is an HP Omen 15-5113dx.
              • apache23
                • 42
                • united states
                I found this datasheet and noticed that the pins on the UMT and UMT3 are numbered different. I was going to order both and try them, but now I'm concerned that I will get something wrong...lol. I guess it's worth a try though, because the motherboard is not going to fix itself and is now just a paperweight.
                  • 21980
                  The marking codes don`t match. If you have the same part,with the same markings on another part of the board desolder it and test it with your multimeter to find out what it is or use a transistor tester.
                  • apache23
                    • 42
                    • united states
                    I've looked for the same chip on this board, as well as on at least 20 other motherboards and nothing. I can't find it online or anywhere and don't know really even how to find it. That's why I'm here.
                    • R_J
                      • 9607
                      What is wrong with the transistor on the board? is it shorted? or just check odd, because if it IS a digital transistor it will check odd (open) because of the built in resistors.
                      • apache23
                        • 42
                        • united states
                        If you look at the single chip (pic on the left), that's the chip on my new motherboard. I used that one so people might be able to see the markings. The pic on the right comparing the 2 chips shows the one that's fried. That's the one I need to find a replacement for.
                        • R_J
                          • 9607
                          Did you check the transistor on the new motherboard to see if it was NPN/PNP or maybe a MOSFET etc. It depends where it is used but it might just be a simple switching transistor, It could also be a custom number for the board maker
                          I do see a BC856W marking code 3Dt, Package style SC-70/SOT323
                          • apache23
                            • 42
                            • united states
                            How do I check to see if it's NPN/PNP or a MOSFET? I'm very inexperienced at this. I just know how to solder...lol. I can only see what you see in the picture. And it is located right by the battery terminal connector. I really appreciate your time and help btw. Thanks!
                              • 21980
                              Post more photos so we can see whats around it
                              • R_J
                                • 9607
                                Use your multimeter in diode test, with one probe on the base then with the other probe check emitter then collector should read around .6xx if not reverse the probes and check again, depending on which probe is on the base should determine the polarity.
                                Based on picture 1, the base would be on the left, emitter on the right, collector by itself at the top.
                                If the new transistor checks like the one on the new MB, you could likely solder it in place even though the leads don't quite match the pads you should be able to solder it on to try it.
                                • apache23
                                  • 42
                                  • united states
                                  OK, y'all are gonna love this! I'm not very good at drawing...lol! Here's a pic of the board and stuff around it and one more pic. Btw, those larger black chips above and to the left are components of the 16GB of RAM.
                                  • apache23
                                    • 42
                                    • united states
                                    I will have to disassemble the laptop, so I should have results within an hour. Thanks for the help. I didn't know what an emitter, collector and base were, but I do now, so thanks!
                                    • apache23
                                      • 42
                                      • united states
                                      Instead of taking the laptop apart to get at the new board, can I use the old one with the bad chip? I just checked it and with the red lead on the base (leg on left) and black on the leg on the right, I get 0.340 and it started dropping and kept dropping slowly. It was at 0.251 when I removed the lead and still dropping. Red on base and black on top leg, I get 0.260, no dropping voltage. With black lead on base and red on right leg, I get .480, then it went up slowly to 0.504, then dropped slowly and kept dropping till it seemed to stop at 0.491....but after about 15 seconds, it dropped to 0.490. After about 25 more seconds, it dropped to 0.489 and that's when I removed the lead. Red lead on base and black on right leg, I get 0.340 and it dropped fast to 0.315...then slowly to 0.308 and seemed to rest there for 12 seconds, then dropped to 0.307 and I removed the lead. Red lead on base and black on top leg, I get 0.455.
                                      • R_J
                                        • 9607
                                        The old chip will be bad, likely shorted if it burnt like in the picture
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • e-repair
                                          Chip identification on hp omen 17cb1008tx
                                          by e-repair
                                          Hello !
                                          i have an to repair an hp omen 17cb1008tx.
                                          i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
                                          can you help me find a reference for this ic ?...
                                          09-23-2025, 03:38 AM
                                        • Loki_Fido
                                          Requesting help identifying chip in Macbook Pro A2485
                                          by Loki_Fido
                                          Hi ya folks,
                                          I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
                                          It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
                                          I replaced it and the SSD are fine. No more shorts.
                                          But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
                                          But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
                                          Chip marking...
                                          08-07-2025, 10:17 PM
                                          HP OMEN X OMEN X by Desktop PC - 900-030 OMEN X i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP OMEN X OMEN X by Desktop PC - 900-030 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-030 boardview and OMEN X OMEN X by Desktop PC - 900-030 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:44 PM
                                          HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
