Apple 820-00244not start
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3575
    • slovakia
    Hello.Have this Apple 820-00244 board that wont start. i dont have QC charger, just usual 5V 1.5A usb charger.
    When i connect it to usb-c port the voltage on fuse is 5V, but after first doubled mosfet i have fluctuating voltage from 5V to 3V
    do u think i need 20V charger to test it?
  • KvnTM
    • May 2018
    • 434
    Re: Apple 820-00244not start
    Yes it needs a 20V charger to work. Use a genuine one.
    Don't just inject 20V into the usb c port! Theres communication between the board and charger. The board will "tell" the charger to go to 20V.
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
      Apple iPhone Charger Schematic
      Apple iPhone Charger Schematic...
      10-02-2024, 01:30 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
