Unknow component
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Unknow component
    Hp folio 1040 g3,
    external board, two wire of the flat cable has burned.
    (pin 11 +3VPCU and 12 GND) there are few component on this small board.
    X322 tested with MK-328, it result as unknow or damaged.
    It's a transistor ?
  • KvnTM
    • May 2018
    • 434
    Re: Unknow component
    Originally posted by jasko_jacker
    Hp folio 1040 g3,
    It's a transistor ?
    Hall effect sensor (lid switch) or some thermal sensor would be my best guess.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      what is this external board called in the Laptop's manual?
      • R_J
        • 9607
        I agree with it being a Hall sensor, Pin1 = supply (+2v) pin2 = output, pin3 = ground
        Likely similar to Allegro A3212
        • R_J
          • 9607
          I made a typo in the above post, it should be:
          I agree with it being a Hall sensor, Pin1 = supply (+3v) pin2 = output, pin3 = ground
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Hp folio 1040 g3,
            It's a transistor ?
            Yes Hall sensor/lid switch beyond any doubt.
            • u666sa
              • Jan 2014
              • 87
              Hp folio 1040 g3,
              It's a transistor ?
              That's a lid switch. With that thing broken your LCD might not turn on (or off). You can short that thing so that it's on all the time. Find ground, short the other two pins. (careful here, I might be wrong, it could be one of those other pins short to ground) Or, better option would be to get similar component from another laptop, doesn't have to be HP, component doesn't have to be same exact one.. Sometimes it works..
              What you should have posted is numbers on the board, from above and from bellow. It's listed as #5 function board 844420-001 on page 16 of maintenance and service guide, and on inet pictures look very different to your board. (different revision) But the sensor is there if you look carefully.
              Your LCD is not turning on? Short pins or take similar part off of another laptop, or order this same board.
              There is no free schematics for your laptop. At least not with information that you provided. However there is boardview (not for your daughterboard) and service and maintenance guide. Attached.
              • u666sa
                • Jan 2014
                • 87
                Hp folio 1040 g3,
                It's a transistor ?
                There you go. Datasheet for your component.
                It is a TSH282 Sensitivity Unipolar Hall Effect Switch
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  The problem is that this small card affects the power button. without it, as usual, when you press the power button, 3.3 V goes to GND and the motherboard changes state and starts up. With the card connected (flat damaged), the 3.3Vs do not go to GND but stand at around 2.1V. If forced to GND, the card also starts regularly with the card attached. I try to replace the hall sensor but it isn't in short so I don't know if the problem regard directly it.
                  • u666sa
                    • Jan 2014
                    • 87
                    It is. Now that we talking about this stuff, I do remember repairing several HP notebooks with similar issues. Solution was always to swap this board. I didn't even bother with sensor, I had similar notebooks in donors, took out the card, and swap it, and it worked.
                      HP EliteBook Folio 1040 G3 Notebook 1040 Specification for Upgrade or Repair
                      This specification for the HP EliteBook Folio 1040 G3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G3 boardview and 1040 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                      09-06-2024, 06:06 AM
                      HP EliteBook Folio 1040 G2 Notebook 1040 Specification for Upgrade or Repair
                      This specification for the HP EliteBook Folio 1040 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G2 boardview and 1040 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                      09-06-2024, 05:30 AM
                      HP EliteBook Folio 1040 G1 Notebook 1040 Specification for Upgrade or Repair
                      This specification for the HP EliteBook Folio 1040 G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G1 boardview and 1040 G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                      09-06-2024, 05:27 AM
                      HP EliteBook x360 1040 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse Hybrid (2-in-1) Specification for Upgrade or Repair
                      This specification for the HP EliteBook x360 1040 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse boardview and 1040 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site....
                      09-06-2024, 08:10 AM
