acer e1-410 battery not charging
  • String2016
    • Nov 2015
    • 2236
    • philippines
    Hi friends, I need help on this acer aspire E1-410 board id:
    EA40-BM MB
    13233-1M
    48.4OC10.01M
    the problem with this the battery no charging it stays at 1percent plugged in, but not increases the charge.I measured the PU4403IC LODRV AND HIDRV PIN15 AND PIN 18 no voltage, checked two mosfet PU4404 PIN 5-8=19V PIN 1-3=2.7V AND ON PU4405 PIN123=0V PIN5678=2.7V with no battery plugged in Charger only .but with battery plugged in and charger PU4404 PIN5-8=19V pin1-3=0.5v
    PU4405 pin 1-3=0.5v pin 5-8= 0v.I noticed also when plugged in the charger there is no charging light. anyone can help me on this please
  • String2016
    • Nov 2015
    • 2236
    • philippines
    Re: acer e1-410 battery not charging
    anyone can help on this please
    • Techtiger
      • Oct 2014
      • 1602
      • france
      what is the voltage on bat2 pin 3 4 5 6 , PU4403 pin 8 9 10 , PU4402 S D G
      • String2016
        • Nov 2015
        • 2236
        • philippines
        bat pin 3-6 no voltages pu4403 pin 8=3.3v pin9=3.3v pin10=0v
        PU4402 S=19V D=0.5V G=19V
        • String2016
          • Nov 2015
          • 2236
          • philippines
          I also found out that mosfet PU4405 Source is shorted to ground
          • Techtiger
            • Oct 2014
            • 1602
            • france
            PU4405 Source is connected to GND leave it there is no commination battery and charger IC/SIO, SCL SAD BAT IN should be 3.3V check PN4301 pin 2 3 4 it's a pack of resisters
            • String2016
              • Nov 2015
              • 2236
              • philippines
              PN4301 pin2=2.6v pin3=2.9v pin4=0v
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Do you have another battery to try? Do I continue to test PN4301 pin 4 and 5 with out battery and adapter
                • String2016
                  • Nov 2015
                  • 2236
                  • philippines
                  I dont have another battery to try. I test PN4301 pin4 and pin5 both have 0v without battery plugged in charger only
                  • String2016
                    • Nov 2015
                    • 2236
                    • philippines
                    But on the PN4301 pin 6 have 3.3v
                    • String2016
                      • Nov 2015
                      • 2236
                      • philippines
                      I find the same good battery to test and test it its working fine, it was dead battery.thanks again techtiger
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • CPUFiddler
                        Acer Nitro 5 AN515-45 not charging
                        by CPUFiddler
                        Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
                        This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
                        I've downloaded...
                        03-19-2025, 07:44 AM
                      • titomno2
                        Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
                        by titomno2
                        Hi guys,
                        I currently trying to figure out why the laptop of my friend did not charge.
                        It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
                        At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
                        I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
                        My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
                        06-11-2024, 11:52 AM
                      • titomno2
                        Acer Nitro AN515-42 Not Charging
                        by titomno2
                        Hi guys,
                        06-11-2024, 02:54 AM
                      • ronaldopdias
                        Acer Aspire 3 A314. Not Charging.
                        by ronaldopdias
                        Laptop Model: Acer Aspire 3 A314
                        Motherboard Model: DA0Z8EMB8C0 - Model: Z8E
                        Charging IC: BQ24780 which I have repalced.
                        Issue Description:
                        I'm experiencing an issue with the charging system on this laptop. The BQ24780 charging IC is not working as expected. The main problems are:
                        1. ACDET is missing (0V):, Reading 0V on the ACDET pin.
                        2. ACOK is not present (0V): Is missing as well.
                        3. No SMBus signals (SDA and SCL are missing): The SDA and SCL signals for SMBus communication are not present. There is no clock (SCL) or data (SDA) activity on these lines.
                        What I Have...
                        12-19-2024, 04:15 AM
