Lenovo G500 : Accidentally disabled the Intel video card in modded BIOS (bricked)
  • bootpanic
    • Nov 2019
    • 20
    • Belgium
    Greetings everyone,
    I'm having trouble in bringing my Lenovo G500 laptop back to life.
    Brand: Lenovo
    Model: G500
    Main board: LA-9631P
    BIOS: 78CN25WW (Modded: advanced options and WLAN whitelist removal unlocked)
    After accidentally disabling the Intel graphics from the advanced BIOS-menu the screen stays black and the laptop is not booting whatsoever. The laptop does turn on (power light comes on) and after a minute or so the CPU fan starts spinning. The person who modded the BIOS warned me not to disconnect the Intel VGA card or not to change the size of the video memory. Unfortunately this was more than six months ago and i forgot about the warnings... In an attempt to enable the onboard AMD GPU I turned off the Intel graphics. Now my laptop is bricked
    Symptoms when power button is pushed are:
    • Power led turns on.
    • CPU fan start spinning after a short while.
    • Don't see the back-lighting turning on.
    • While on the laptop beeps when the power adapter is plugged in or unplugged (normal behavior).
    What I've already tried without success is the following:
    #1 During boot-up, if pressing Fn+F2 to access the BIOS.
    #2 Removing the AC adapter, battery and disconnecting CMOS battery, then pressing the power button for 20secs.
    Reconnecting the AC adapter without putting the battery back in and pressing the One Key recovery button.
    #3 Disconnecting all power sources and leaving the laptop overnight.
    #4 Removing AC jack, Main Battery, and disconnecting CMOS Battery. Removing HDD and all DIMMs. Waiting 10 mins. Pressing and holding power button for 30 sec. Connecting CMOS Battery and one DIMM only and inject AC jack (without Main Battery). Boot laptop.
    #5 Shorted "clear CMOS" (CLRP2) pads on main-board beneath hard-disk slot (picture attached) and cycling power on (1 minute) and off, remove short.
    None of the above changed anything...
    I've attached some images with extra info about the laptop.
    Any thoughts or advise is greatly appreciated.
    Thanks in advance.
    Best regards,
    Patrick
  • KvnTM
    • May 2018
    • 434
    Re: Lenovo G500 : Accidentally disabled the Intel video card in modded BIOS (bricked)
    Remove CMOS Battery (if it has one) i believe BIOS Settings are stored in SRAM.
    Remove battery and unplug it from AC.
    Wait a minute and start it with ac or battery. Doesnt really matter.
    If this doesnt work you may have a serious problem if the settings are stored in EEPROM/NVRAM.
    Then you‘d have to reprogram or replace the EC.
    Please correct me if someone knows better.
    Does it boot into windows? You could try to connect an external display if only the dedicated gpu is working.
    • lefos
      • Nov 2013
      • 321
      • Greece
      I guess that you have to flash the BIOS again.
      Do you have the modded BIOS dump ?
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        I'd agree with KvnTM on removing the CMOS battery. The modded BIOS should, by default, have the Intel iGPU enabled and set to a default memory size.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • KvnTM
          • May 2018
          • 434
          I‘m not sure if this will fix the issue. Usually there are no settings stored in the ROM chip. Maybe you could flash the „normal“ bios which will fix this itself.
          • KvnTM
            • May 2018
            • 434
            Maybe those „special options“ are stored in NVRAM/EEPROM as a initial configuration from the manufacturer. Those wont change when disconnecting the cmos battery...
            And MAYBE he could change this option blind if the laptop does enter the bios without the iGPU.
            Some reference Video would be helpful for this. Pretty sure there are Videos on the Internet.
            • digitalpc
              • Jun 2016
              • 305
              • .DLL
              do u have video with vga/hdmi cable
              • bootpanic
                • Nov 2019
                • 20
                • Belgium
                Thanks for your reply KvnTM
                I did already tried what you are suggesting, thanks anyway :-)
                • bootpanic
                  • Nov 2019
                  • 20
                  • Belgium
                  Thanks for your reply.
                  I'm going to try to flash the original BIOS.
                  I attached the modded BIOS.
                  • bootpanic
                    • Nov 2019
                    • 20
                    • Belgium
                    I forgot to mention that i did try to connect a monitor to HDMI and analog VGA, unfortunately no output...
                    • bootpanic
                      • Nov 2019
                      • 20
                      • Belgium
                      Does anybody knows where the BIOS flash chip is located on this board (LA-9631P)?
                        • 21841
                        Short the CLRP2 pads. Page 14 in the schematic.Remove the bios battery first then power up while shorting.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          NVRAM settings are stored in SPI ROM with the BIOS usually. Some of them get invalidated with clear CMOS, others don't. If clear CMOS doesn't help then indeed flashing the BIOS can be a good idea.
                          • bootpanic
                            • Nov 2019
                            • 20
                            • Belgium
                            Thanks for you reply
                            I have already done that.
                            It is mentioned in my initial post :-)
                            • bootpanic
                              • Nov 2019
                              • 20
                              • Belgium
                              Hi piernov,
                              Thanks, gonna try that tomorrow...
                              Greetings,
                              Patrick
                              • bootpanic
                                • Nov 2019
                                • 20
                                • Belgium
                                Hi everyone :-)
                                First I want to say THANKS to all the people who replied to my post, trying to help me out! ;-)
                                Today is disassembled my laptop and used a Raspberry pi 3 to flash the BIOS of my Lenovo G500 laptop with the original one and it fixed the problem. The laptop is back fully functional :-)
                                Cheers,
                                Patrick
                                • surecando
                                  • Nov 2019
                                  • 14
                                  Cool!
                                  • q2v5
                                    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                    by q2v5
                                    Lenovo T480s
                                    Model 20L8-S3TE00
                                    Board ET481-U10
                                    Chip MX25L12873F
                                    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                    08-15-2024, 10:40 PM
                                  • EbrahimSiami
                                    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                    by EbrahimSiami
                                    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                    **What I have tried so far:**
                                    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                    07-02-2025, 02:31 PM
                                  • cappernicus
                                    Acer Spin 5 - Lenny_ICL (19771-1) -- Dead - PM_SLP_S3# held low
                                    by cappernicus
                                    Laptop model: Sp513-54n-74V2
                                    Testing power rails (separated by chip) reveals:
                                    19V_DCBATOUT - (active)
                                    5V_AUX_S5 - (active)
                                    5V_S5 - (active)
                                    3D3V_AUX_S5 - (active)
                                    3D3V_S5 27Ω - (good) - enabled by Nuvoton chip
                                    1D8V_VCCIN_AUX - (good) - enabled by 1D8V_S5 PG signal -- (dependent on 3D3V_S5)
                                    1D8V_S5 41Ω - (good) - enabled by 3D3V_S5 PG signal
                                    1D05V_VNN_BYPASS - (good) - enabled by 1D8V_VCCIN_AUX PG signal...
                                    09-25-2024, 05:19 PM
                                  • hotgly
                                    Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
                                    by hotgly
                                    After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
                                    The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
                                    I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
                                    Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
                                    Serial number: 0F00S2Y22353BF
                                    Intel(R) ME Code Versions:
                                    BIOS Version 12.200.143
                                    MEI Driver...
                                    05-15-2024, 02:20 PM
                                  • Fr33man
                                    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                                    by Fr33man
                                    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                                    *Novo button power on
                                    *Disconnected internal battery...
                                    09-23-2024, 01:16 PM
