Acer c5v01 la-e892p rev 1c battery prob
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have this acer aspire A615-51G SERIES MODEL # N17C4
    Before I opend the laptop the battery was full functional now after replaceing the keyboard the battery wont charge and wont detect , Ive check the voltages on the board IN pjp201 withouth the battery im just getting 4v , what may be the cause of this problem?
    THE BATTERY WAS AC14B8K
    I REALLY NEED HELP
    MOD Edit: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=123072
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: Acer c5v01 la-e892p rev 1c battery prob
    I REALLY NEED HELP
    im getting 19v on pr209
    and im getting 3.3v on pr210
    image upload
      • 21204
      PR209 and PR211 is a voltage divider. check SWG1 on page 39 of the schematic, BI SW is the Battery In switch, it needs pressing in for the battery to be detected.It should press in when you screw the base cover back on .Those base screws around acer battery switches (and split holes on other acers) tend to come loose over time,stopping the laptop from switching on or the battery being detected .
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Thank you very much sir you really help me 💐
        • M4n0l0307
          • Nov 2020
          • 167
          • Colombia
          Thanks Master !
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • DenK
            Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
            by DenK
            Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
            1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
            12-06-2024, 01:29 AM
          • survivalbloke
            Acer Predator Helios 300 - will not power up if battery is CONNECTED
            by survivalbloke
            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
            06-25-2025, 12:20 PM
          • ahmarzo
            Acer TMX314-51 laptop battery problem
            by ahmarzo
            I have acer laptop tmx314-51 with part no 6050A3020501.
            The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
            But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
            I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
            The schematic is not available...
            04-11-2025, 09:14 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
