macbook pro 15 inch retina 2014 remove remote management permanently
  • adiljan
    • May 2019
    • New Zealand
    hi there how can i remove remote management permanently ?
    model: macbook pro 15 inch retina 2014
    can i remove with EFi chip or other way? plz help me thanks
  • bussincaps
    MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
    by bussincaps
    Hello All,
    tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
    Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
    eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
    Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
    I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
    08-03-2023, 12:57 PM
  • jasonr2000
    MacBook Pro 2014 Retina Power Cycling
    by jasonr2000
    hi guys I have the above mentioned MacBook Pro 2014 Retina 13"
    and its power cycling no matter what I do.
    it powers on chime turns off does the same over and over.
    I've checked voltages and they are going up and down the 5v one gets there then falls to 0v 3v3 also does the same thing goes up to 3v then falls off.
    any ideas where I can check next ?
    I did notice a slight bit of corrosion in the are highlighted in the image.
    none of the water indicators have changed colour so I'm not sure how it got wet there...
    01-11-2024, 09:41 AM
  • ritalo
    MacBook Air 13 2014 - Remove EFI password
    by ritalo
    I have a MacBook Air 13 inches 2014.
    I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
    I know how to remove the password with a usb programmer.
    I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
    Then I have to find this value in the file : $SVS because it indicate where is the password.
    But I can't find the value.
    I have attached the file​
    Thank...
    05-14-2024, 12:10 PM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • itsmeapple
    MacBook Pro Charges When Off, But Not When On (MBP 2014 15 Inch) 820-3662-A
    by itsmeapple
    I'm facing an issue with my MacBook Pro.
    When it's switched off, it charges while the battery is connected. However, when it's powered on, the charging stops after a few seconds.
    Another strange thing is that when I disconnect the battery and plug in the charger, the MacBook Pro turns on and runs without any issues.
    I've already tried using a different OEM charger, but no luck. I even swapped the charging port DC-IN, but the problem persists.
    Has anyone else experienced this issue before?
    Thank you!...
    02-21-2025, 02:22 PM
