Dell Inspiron 5567 Battery not charging (LA-D801P)
  • m3g4tr0n
    • Aug 2011
    • 88
    laptop wont charge the battery. battery shows as charging in bios/system info
    here are some measurements i took.
    DC Jack
    19v
    3.3v PSID
    Battery only - Power Off
    1-3 GND 0v
    4 SYS_PRES 0v
    5 BATT_PRS 0v
    6 DAT_SMB 0v
    7 CLK_SMB 0v
    8-10 Batt+ 10.7v
    Battery only - Power On
    1-3 GND 0v
    4 SYS_PRES 0.0022v
    5 BATT_PRS 0.023v
    6 DAT_SMB 3.3v
    7 CLK_SMB 3.3v
    8-10 Batt+ 10.7v
    Adp only - Power Off
    1-3 GND 0v
    4 SYS_PRES 0v
    5 BATT_PRS 3.38v
    6 DAT_SMB 3.38v
    7 CLK_SMB 3.38v
    8-10 Batt+ 0.05v
    Adp only - Power On
    1-3 GND 0v
    4 SYS_PRES 0.0022v
    5 BATT_PRS 3.38v
    6 DAT_SMB 3.38v
    7 CLK_SMB 3.38v
    8-10 Batt+ 0.0v
    Adp and Batt - Power Off / On same voltages
    1-3 GND 0v
    4 SYS_PRES 0v
    5 BATT_PRS 0.032v
    6 DAT_SMB 3.38v
    7 CLK_SMB 3.38v
    8-10 Batt+ 11.27v
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Dell Inspiron 5567 Battery not charging (LA-D801P)
    You have to try with a new battery or voltage on pin 8/9/10 must be higher than+11V in the Schematic pl700 +17V !
    • m3g4tr0n
      • Aug 2011
      • 88
      ordered a new battery.
      could the charging ic be faulty? (PU703 / ISL88739HRZ)
      • Techtiger
        • Oct 2014
        • 1602
        • france
        not for the morment
        • KvnTM
          • May 2018
          • 434
          Just charge the battery with a lab psu for a little bit.
          Limit the current to 1A and let it charge to a reasonable voltage.
          That way you could rule the battery out. I revived many laptop batteries in the past with this method.
          • m3g4tr0n
            • Aug 2011
            • 88
            What voltage should I charge with? Same as written on the battery?
            • KvnTM
              • May 2018
              • 434
              Charge it with constant current and limit the voltage to the pack's nominal voltage.
              • seosan
                Ronaldo 035
                • Apr 2018
                • 27
                • japan
                In schematic page 51 :
                "Adapter protection:
                if battery removed, adaptor only,
                then trigger the H_PROCHOT#,
                keep @ in BOM since battery can not
                be removed by end user"
                • lazybigyan
                  • Mar 2017
                  • 79
                  • Nepal
                  I have lil bit different issue with not charging. My mobo can not recognize the charger. Other thing is good. Charger been change. Please help me. Thanks
                  • mon2
                    • Dec 2019
                    • 14216
                    The laptop works but complains about the adapter? Or does the laptop not turn on at all?
                    Is the charger from Dell? The charger from Dell has an ID. The logic board checks for the valid IDs. Post full details and pics of the charger.
                    What is the history of this laptop? Liquid spill?
                    • lazybigyan
                      • Mar 2017
                      • 79
                      • Nepal
                      I found the problem in ide section. I change PQ6 then charger been detected. Solved. Thank you for your concern.
                      • dreico33
                        • May 2018
                        • 36
                        • Bolivia
                        Hellow guys i have the same problem. I took some measurements and in some point i got confused. Just a quick question: The PS_ID Signal needs 3.3 V on the dc cable right? Would have any diffrence at all if my multimeter shows 3.0V? Could be the Dc Cable?
                        Thank you.
                          DELL Inspiron 5567 Notebook 5000 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 5567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5567 boardview and 5567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5567...
                          09-06-2024, 08:01 AM
