Dell XPS 9343 No Sound
  • iceze
    • Oct 2019
    Hi guys
    Hope you can maybe help.
    Have a Dell XPS and sound doesn't work in Windows 10. I have tried reloading windows 10, 8, bios and all drivers. The sound works in the Dell boot diagnostics utility and I did try a Linux live usb and it works upon second boot in that.
    Having researched it looks like the motherboard has a realtor ALC 3263 which can switch between HDA or I2S audio depending on OS.
    So if I load Ubuntu once then restart into windows the machine outputs in HDA mode and works all fine. As soon as the laptop is restarted or sleeps, it resumes back into I2S.
    Tried so many different combinations and now I'm thinking maybe I can force HDA mode somehow. There is no option in the bios. Ive
    I was looking at the motherboard schematics but I don't have much experience with electronics schematics and need help.
    I see that the mode HDA and I2S is mentioned on there. Is there anyway I could maybe toggle it to only use HDA audio by physically. Could there be a reason why I2S is failing and HDA is fine?
  • lvalius
    • Jan 2017
    • 35
    • Lithuania
    Re: Dell XPS 9343 No Sound
    I remember I had same problem with this model once, you need to download correct drivers, but I do not remember which one. Try all version from dell support page one by one, I think it should help.
    Because if it is working in bios and Linux it should work in Windows too and that's just bad drivers causing the problem. Don't give up.
    Original Dell parts for sale
    • iceze
      • Oct 2019
      Tha k you for your reply Ivalius. I have tried so many drivers and reinstalls of windows I was beginning to think it must be some kind of hardware fault maybe. I have read a few threads of others with similar problems but there seems to be no one solution and the threads are from years ago.
      Given me a little hope so I'll keep trying more drivers. ( Must have tried at least 7+ different ones).
      I'm leaning towards some potentially intermittent fault atleast to do with I2S though. I will keep trying in the mean time.
      It's just surprising how the audio works so easily after rebooting from Linux.
      • rediii
        h???, spurrrn
        • Mar 2018
        • 487
        • somewhere in europe
        did you try a bios-update? i had the exact same issue on an asus-model.
        • iceze
          • Oct 2019
          I have now tried maybe 6 different bios', different drivers, and 3 different windows with no luck. Sound works fine on Ubuntu (no WiFi but I didn't really want to troubleshoot that).
          I'm losing hope on trying to fix this in windows 10.
          @rediii can I ask what laptop you had and how you resolved it?
          I'm thinking maybe I can somehow boot Ubuntu kernel and then reboot into windows. All done in the background automatically. That way I can force the system into I2S atleast for each reboot. BuT that's a long-winded way and I'm not great at Linux scripting!
          Any help would be a massive help.
          • rediii
            h???, spurrrn
            • Mar 2018
            • 487
            did u try to disabled all audio enhancements in windows 10? did you try (if it is there) to disable the intel audio/nvidia driver? did u try to uninstall the audio driver with DDU? did u try to uninstall any app that is combined with any audio option? pls tell me. did u test to resolve any hardware or software issue with the dell support assist (yeah it's crappy but sometimes...). and did u uninstall the drivers completely (device manager with checkbox activated, sounds stupid but u never know?). try to uninstall camera and microphone driver. reset all sound settings in windows 10 (including camera and microphone)!
            • ex250
              Kenwood SW-505D no sound issue and pops from time to time when it works
              by ex250
              Hello mates,
              I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
              It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
              12-29-2024, 03:27 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • TopPop
              Dell XPS 15 9560 laptop with no sound
              by TopPop
              I don't know the history on this laptop. However it is in good condition and everything in it seems to be working except the sound. I tried troubleshooting that several ways, assuming it was a software or driver issue, but in the end even in the Dell diagnostics which run outside of Windows there were no tones played when running the audio diagnostics. It is as if the audio output device is completely missing.
              So, I thought maybe the problem was the little audio board (Dell part 5G0HC) that plugs in to the motherboard (Dell part YH90J). Maybe the audio board was dead. So I ordered...
              11-24-2022, 10:23 PM
            • TheQuentincc
              Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
              by TheQuentincc
              I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
              06-26-2025, 01:44 PM
            • CapLeaker
              Dell ATX PSU won’t start, but forcing it works fine?
              by CapLeaker
              Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
              Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
              10-28-2024, 06:59 PM
