Dell E5440 completely dead, no LED.
  • Andreasbest
    • Aug 2014
    • 1176
    • Hellas ( Greece )
    Hello!
    I have a Dell Latitude E5440 on bench that is completely dead, no led, no other activity like there is no power adapter connected.
    The power_jack_in has voltage 19,5V, the PL4 has 19,5 in both sides and the PQ 4 has 19,5 Voltages too except the pin 4 that has 9,37v.
    Any advice?
    Thank you in advance!
    schematic: https://drive.google.com/file/d/0B6I...tOR2VoV3M/view
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: Dell E5440 completely dead, no LED.
    Everything is fine there, you have to check further down. The main power rail +PWR_SRC_AC, the 3V and 5V power rails, etc…
    • Andreasbest
      • Aug 2014
      • 1176
      • Hellas ( Greece )
      PL400 that is on PWR_SRC_AC rail has 19.5v in both pins so i guess PWR_SRC_AC is fine?
      I don't know about 5v and 3v rails, can you help me locate them?
      Thank you very much!
      • piernov
        • Jan 2016
        • 4436
        • France
        Sorry I wanted to say "+PWR_SRC", on PL401 for example.
        The 3V/5V power rails are on page 52:
        +3.3V_RTC_LDO
        +5V_ALW2
        +3.3V_ALW
        +5V_ALW
        • Andreasbest
          • Aug 2014
          • 1176
          • Hellas ( Greece )
          PL301 has 17V in one side and 0v on the other
          No 3.3V in pin 3 and pin 7 of PU51
          No 5v in pin 13 in PU51
          • Andreasbest
            • Aug 2014
            • 1176
            • Hellas ( Greece )
            *Correction PL301 has 17V in both sides
            Pin 7 of PU51 has 0,25V
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Check TPS51125 pin 12 VIN pin6 EN2 pin20 En1
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Find out also if the PS_ID is ok
                • Andreasbest
                  • Aug 2014
                  • 1176
                  • Hellas ( Greece )
                  Pin 6 = 0.14v
                  Pin 12= 17.27v
                  Pin 20 = 0.12v
                  I don't think there is a problem with PS_ID as in this case the laptop power on but doesn't charge, in my case the laptop is completely and absolutely dead, no sign of life at all.
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Page 52 it’s the 5/3V regulator IC
                    • Andreasbest
                      • Aug 2014
                      • 1176
                      • Hellas ( Greece )
                      Yup got it, search didn't return result so i looked for it manually.
                      Check the voltages i posted.
                      • Andreasbest
                        • Aug 2014
                        • 1176
                        • Hellas ( Greece )
                        can someone help me please?
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          Originally posted by Andreasbest
                          Pin 6 = 0.14v
                          Pin 12= 17.27v
                          Pin 20 = 0.12v
                          The voltage of pin 12=17.27V this was taken with Battery ? You have to change PU51 if it's not outputting LDO 3/5 pin13 & 3 test the resistance to GND on those pins
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            Pin 6/20 should be around +3V to PMW to function
                            • Andreasbest
                              • Aug 2014
                              • 1176
                              • Hellas ( Greece )
                              No battery on, only charger and nothing else.
                              What do you thing?
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                What do you thing?
                                +pwr_src 17V means PQ400 is not switching on check Voltage on pin 5 and 123
                                • Andreasbest
                                  • Aug 2014
                                  • 1176
                                  • Hellas ( Greece )
                                  Pin 1 19v
                                  Pin 2 19v
                                  Pin 3 19v
                                  Pin 5 19,6v
                                  • Andreasbest
                                    • Aug 2014
                                    • 1176
                                    • Hellas ( Greece )
                                    Any advice?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      +DC1_PWR_SRC is the rail name which goes as VIN on Pin12 of PU51 which you have measured at 17V. It should be stable 19V. Check PL51 for corrosion or PQ51 pin5 voltage.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1176
                                        • Hellas ( Greece )
                                        Hello and thank you very much for helping me!
                                        PQ51 pin 5 = 17V
                                        PL51 = 17v in both pins.
                                        No corrotion, do you want to remove it and measure again?
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • Andreasbest
                                          by Andreasbest
                                          Hello!
                                          I got a Dell E5440 that is completely dead, charger doesn't detect any shortcircuit so remains lit when i plug it on laptop.
                                          No signs of life at all, i only detect some heat on PQ4.
                                          Plus PQ4 has 19v on pins 1,2,3 & 4 and only 1.8v on the other.
                                          I replaced it but no luck, same behavior.
                                          Any help appreciated, thank you in advance!!!
                                          Schematics and Boardview attached...
                                          10-11-2021, 10:02 AM
                                        • diamon
                                          Dell Latitude 5520 completely dead
                                          by diamon
                                          I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                                          Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                                          After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                                          Have checked with a thermal camera, and there are a couple of things...
                                          03-05-2025, 02:23 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Francesc V.
                                          Dell dockstation WD15 is dead
                                          by Francesc V.
                                          Hi:
                                          A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                          Here are the findings, followed by good pictures. :-)
                                          When pluged in, LED3 glows
                                          Measuring some voltage in the circuit.
                                          Inductors
                                          - PL202 has 5V
                                          - PL201 has 3.3V
                                          - PL300 has 1V
                                          V. Regulators
                                          - UT30 has 19v as input and 6V as output. It seems ok.
                                          - UT27 (same reference as UT30, has no input/output voltage).
                                          Thermal find...
                                          07-09-2025, 12:12 AM
