Hello, please I need help, I have a mb that I'm working on dell n5040 part number xf5901 24p... I've checked all the coils none is short to ground.... 19v is present but on the 5v coil I get 2.4v and 3v coil I measure 0.13v ..... I tried to trace back the problem with the help of schematic but I'm stuck, no 3.3 aux volt present and having difficulty finding the origin
Dell N4050 no 3.3v auxiliary volt
Re: Dell N4050 no 3.3v auxiliary volt
Do you mean 3D3V_AUX_KBC?? If it is so then you need to check Q2703. You need to check page 27 of schematic where run power and psl logic is described. IF it is 3D3V_AUX_S5-then check tps 51125 ic. Since you are not having 5v/3v on coil , i beleive your problem lies in tps 51125 or related components.
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
hi,
dell n4050(10315-1) all voltage are ok , but no display
DC power supply getting 0.52 amp. with ram and without ram same amps
i have changed bios and RAM then same issue
plz give me any idea for this solution -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
- Loading...
