Hi all, I am working on a MacBook Air Logic board 820-00165-A. I am getting all the main voltages 8.5, 3.3, 5.0 Voltages but I am missing the PPVCC S0 CPU 1.5v. I checked on L7310 & L7320, no voltage on the output of these inductors & due to this there is no fan spin. The Magesafe jack LED indicator are correct. I get PP5V_S0 VCC voltage on both U7310 & U7320 but no phase (pin 8) on these chip. I do not measure any kind of shorting, all seems to be fine. Can anyone help, totally lost....
					Apple MacBook Air 820-00165 no PPVCC S0 CPU
Re: Apple MacBook Air 820-00165 no PPVCC S0 CPU
ALL_SYS_PWRGD? CPU_VCCST_PWRGD?
If the fan is not spinning you're probably missing something else… Go down the list of power rail again to see what's present and what's missing.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
Thanks, Q8150 has liquid spill green corrosion on the pins, I have no idea why, this is why all pin got rusty. I replaced Q8150 but still no luck. Upon more diagnostic, as you told me I checked the voltages on CPU_VCCST_PWRGD & ALL_SYS_PWRGD_R... NO 3.3v or 1.5v. Upon more microscopic observation I & checked the circuit lines continuity of Q8150., I got a broken trace circuit on pin 5 of Q8150 & R8153. I joined the lines & all happy Mac once again. Thanks for the help. All works fineComment
Hello, I have the same problem, but I am not sure what is wrong, I suspect PP3V3_S0 because it has a voltage of 0.5V, but I also do not have a voltage in ALL_SYS_PWRGD
I leave my readings in Q8150
pin1:_0.77V
pin2:_Unconnected
pin3:_0.11V
pin4:_0.10V
pin5:_1.10V
pin6:_3.16V
pin7:_0.16V
pin8:_Unconnected
I hope you can help me.Comment
confirm the voltage on EN2 (P3V3S5_EN_R) pin # 21: 3.41V
I will cleanup and confirmComment
Good ENABLE voltage for U7501 yet the output is still not valid.
Confirm the voltage @ L7560, pin # 2 (PP3V3_S5_REG_R).
If this voltage is not ~3v3, check for a short on this rail as follows:
a) Remove all power.
b) Meter in resistance mode.
c) Check the resistance to ground of L7560, pin # 2 (PP3V3_S5_REG_R).Comment
Confirm voltage on L7560 pin # 2 (PP3V3_S5_REG_R) : 3.31VGood ENABLE voltage for U7501 yet the output is still not valid.
Ok - you have at least a broken trace to this load switch.
This part (U8030) is acting like a solid state relay. When the C2 pin (EN) is logic high (~3 volts), this switch will pass the INPUT voltage (pins A2/B2) to the OUTPUT (pins A1/B1).
However, the PP3V3_S5 rail is not reaching this IC.
Need to check the P3V3S0_EN at other locations on the logic board.
What is the voltage ?
So in summary, P3V3S0_EN = ~3v3 volts & PP3V3_S5 = ~3v3 => will turn on this switch to power downstream devices which are required.Comment
Voltage on P3V3S0_EN = 3.3VOk - you have at least a broken trace to this load switch.
i will resold and clean U8030 and put the new capacitor (C8030)
Edit: the rail on (C8030) pin#1 whit conection on U8030 pin #2-4 broken.Last edited by judamex; 08-08-2022, 04:54 PM.Comment
I replaced the U8030 that was broken and now it turns on fine, thanks for the help!
			by samstownHello,
This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
Claude... -
			by arahbanHello Gentlemen,
I am working on an apple MacBook A2442 board pn 820-02098-A with a visible short on the PMIC U7700 MVK-PLUS as per the schematics
I have a donner board from apple macbook pro m1 A2338 PN 820-02020 and I saw that the PMIC U8100 TMLT46B0-JPE could be a possible replacement for the U7700
Can you please help me confirm if the U7700 can be replaced with U8100 ?
APL1098 is it the same as APL1096
Thank you very much in advanced
Ahmad -
			by a_p3rsonHi there,
I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
This daughterboard uses an interesting...-
							Channel: Schematic Requests ONLY!
04-21-2025, 11:41 PM -
			by mferna14Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
			by stefanbsThe laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?05-11-2025, 01:08 AM
 - Loading...
