can a 40pin led connector convert to 30pn
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I hAVE a question is it possible to convert a 40pin led lcd to 30pin connector?
  • Conste
    • Oct 2018
    • 235
    Re: can a 40pin led connector convert to 30pn
    I don't think so, because 40 pin is eDP and 30 pin is LVDS interface, so the data interface is not the same -> communication will not work
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      it is vice versa,30 pin is edp. Simple conversion is not possible...
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Usually 40 pin is LVDS and 30 pin is eDP but I have seen 40 pin eDP aswell.
        There are LVDS->eDP converters. I know that some people have used a 30 pin eDP screen from Lenovo Carbon on a T430 using that converter.
        • Tomylee
          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
          by Tomylee
          Sorry for the person who’s going to read all this !
          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
          07-11-2025, 11:52 AM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • 5mall5nail5
          Help identifying connector for ASUS 4090 Strix RGB LED connector
          by 5mall5nail5
          Hi All -
          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
          05-04-2025, 07:47 AM
          HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
          This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
          09-06-2024, 11:17 AM
        • bussincaps
          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
          by bussincaps
          Hello All,
          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
          08-03-2023, 12:57 PM
