Hp 2000 issue
  • hazim
    • Mar 2016
    • 62
    • egypt
    Hp 2000 issue
    hp model : 2000-2d03sx mb : 6050a2498701 a02
    no power on power supply ampere 00
    fet q9448 bad i replace it
    after that volt on charger coil 19 v
    on charger resistor 19v
    but no 5 - 3 volt at all power system ic 11-fh in schematic tps51123rge
    on power system q309 0 volt
    q317 19 v on D
    q310 0 volt
    q318 19 v on D
    on battery connect 19 v and 0.5 volt
    i need your help
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Hp 2000 issue
    The battery connector 19V to high check Q9448 fet for short , pin 1 2 should be 9-12 V, check BQ24728 all pins Voltage report back , trace ADP_ID for Voltage, check pin 16 17 8 of U307
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: Hp 2000 issue
      Start with pg7 of schematic and check voltage on all pins of Q9447/9448,Q310 first. After these measurements, if everything is fine, lets probe U307 IC. but basic dc in fets check first.
      • hazim
        • Mar 2016
        • 62
        • egypt
        Re: Hp 2000 issue
        hi i examine mb and checked voltage
        Q9447 G20 S20 D20
        Q9448 G19.4 S19.7 D20
        BQ27728 : U302
        1- 0 V
        2- 19 V
        5- 0.18 V
        6- 0V
        7-0 V
        8- 19.7V
        10 - 19.5V
        15- 2.7
        20- 20 V VCC
        Q318 ALL 0 VOLT
        Q310 G0 S0 D20V
        U307 TPS
        PIN
        8- 0V
        16- 0.0016 VIN
        17- 0.5V
        18- 0V
        D301 0.9 ------1.1 V ADP ID AS I THINK
        D305 0--------- 2.7 V
        NO SHORT IN FETS
        NO HEAT
        where is the problem
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          Re: Hp 2000 issue
          U302 may be the faulty part. If you have any spare, try to replace it and check it.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Re: Hp 2000 issue
            Q9447/48 gate voltage is wrong. They are N channel fets, so gate voltage should be higher than souce. So U302 is not working. So first, replace U302 as suggested by@raajkumar.
            • piernov
              • Jan 2016
              • 4439
              • France
              Re: Hp 2000 issue
              Q9447 is shorted.
              • hazim
                • Mar 2016
                • 62
                • egypt
                Re: Hp 2000 issue
                Q9447 is shorted and i replace it with n-chanel 8444
                after that G0 S0 D20
                Q9448 shorted again i replace it with n-chanel 8444
                all S0 D0 G0
                i found Q305 short and its place on mb short also
                u302 vcc 0
                there is capacitor near u302 vcc capacitor short
                • hazim
                  • Mar 2016
                  • 62
                  • egypt
                  Re: Hp 2000 issue
                  hi
                  after more diagnostic and studying schematic
                  i find d345 bad and ceramic capacitor short near ic u307 by inject volt on charger resistor
                  i replaced and lap power on
                  thank you so much
                  • mcthr
                    • Aug 2019
                    • 25
                    • Philippines
                    Re: Hp 2000 issue
                    how many volts un inject sir in 19v resistor
                    • lapfix
                      • Mar 2020
                      • 2764
                      • my workshop
                      Re: Hp 2000 issue
                      You can start by 1volt/1amp
