RV511 Problem
  • String2016
    • Nov 2015
    • 2238
    • philippines
    RV511 Problem
    https://www.badcaps.net/forum/showthread.php?t=78845
    I tried above still the same issue turns on fan at full speed but no display already tried the bios of piernov on this thread same result. maybe the PCH is dead
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: RV511 need clean me bios
    Vcore present??
    • String2016
      • Nov 2015
      • 2238
      • philippines
      grey coil near cpu has 0.89v and caps near cpu has 1.08v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        There should be probably three coils near cpu-2 for vcore and 1 for gfx core. Have you measured all of them??
        • String2016
          • Nov 2015
          • 2238
          • philippines
          the two coil near cpu together has 0v both the other one coil has 0.89v
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            So, that does mean you have missing vcore. What's the mb marking? Lets first check schematic avlbl or not. Btw, did you checked fets connected to vcore circuit??
            • String2016
              • Nov 2015
              • 2238
              • philippines
              board id is BA41-01433A. the two grey coil together vcore is beeping all sides to the ground.when i check continuity on the backside for the fets the one fet is beeping it has mark AO6710
                • 22012
                Re: RV511 Problem
                Lets keep repairs in the main forum, and bios requests in the bios requests forum please.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  Re: RV511 Problem
                  update: i replaced the mosfet 6710 with the same mosfet but still the same issue still no vcore voltages on two grey coils
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Re: RV511 Problem
                    Don't randomly replace components or you'll cause more problems. Try to understand why they are not told to turn on.
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      Re: RV511 Problem
                      i replaced the mosfet with the same value. it seems that this vcore coils are shorted to ground
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Re: RV511 Problem
                        Vcore coils has very low resistance to gnd. If its below 005-then it may be shorted. Measure in diode mode with black probe on gnd and red on coils.
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          Re: RV511 Problem
                          in diode mode balck to ground and red to two coils it measure 002
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            Re: RV511 Problem
                            Use resistance mode. Sandy Bridge can be 2-3 ohms without problem. Ivy Bridge can show 1.5 ohms and be perfectly fine.
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              Re: RV511 Problem
                              resistance mode shows 2.2ohms but two coils both sides shorted to ground
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                Re: RV511 Problem
                                Also this has a removable CPU so you can measure without CPU.
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  Re: RV511 Problem
                                  if i remove the cpu and measured resistance without cpu it shows 1.5ohms
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    Re: RV511 Problem
                                    anyone can help on this
                                    • theone111
                                      by theone111
                                      3. Problem: TV shuts down
                                      07-22-2024, 10:36 AM
                                    • Zeonalbasta
                                      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                      by Zeonalbasta
                                      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                      09-13-2024, 01:17 PM
                                    • Gibon378
                                      Problem with stopping audio and video for no reason
                                      by Gibon378
                                      PC Specs:
                                      • CPU: Ryzen 5 1600
                                      • GPU: GTX 1080 Palit JetStream
                                      • MOBO: ASRock ab350 PRO4
                                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                      • PSU: XFX 650W (don't remember what model)
                                      • OS SSD: ADATA SP920
                                      • OS: Windows 10 21H2
                                      Problem description:
                                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                      11-19-2022, 09:41 AM
                                    • perzyk23
                                      Lenovo T580 - LCD Panel problem - error 0288
                                      by perzyk23
                                      Good morning,
                                      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                      10-25-2024, 12:42 AM
                                    • lazaro.089
                                      Asus Zephyrus M16 / GU603ZW problem
                                      by lazaro.089
                                      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                      CPU: Core i9-12900H
                                      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                      08-26-2025, 06:33 PM
