laptop tosiba s865-s5381 fuse burning with lines next charger
  • mmaewbsoft
    • Apr 2018
    • 65
    • yemen
    i relace fuse and and connect small cable from line red charger to fuse
    all mosoft 19v and and 4 pin 7-6
    TPCA8065 this mosoft is shourted out of board how can i change it with any mosoft i cant find like this TPCA8065
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: laptop tosiba s865-s5381 fuse burning with lines next charger
    It’s a N-Channel Fet you can replace it with a any N-Channel 30V Fet upload the Schematic
    • mmaewbsoft
      • Apr 2018
      • 65
      • yemen
      TPCA8065-N-Channel like those p219-7114-f8707 and tpc8212h or 4800b
      • mmaewbsoft
        • Apr 2018
        • 65
        • yemen
        sorry for mistake mosoft is n3018ss hc
        • corrize
          Replacing resistor fuse in Sony DV charger
          by corrize
          Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
          So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
          It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
          06-30-2025, 06:59 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
