dell inspiron 15 3542
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    the laptop is dead:
    no power:
    5v and 3.3v are present
    3v on power switch is present
    volts on charging battery are present
    volts on bios are present:
    when i press the power button, the volt on it will be 0
    i reflashed bios but the same error
    no evidence of life
    any help please
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    Re: dell inspiron 15 3542
    the voltages on bios is 3.3v on all pins except the 4th pin which is GND
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Check for AC IN KBC / AC_PRESENT , DC Jack light is on? Are you using a original charger ?
      • mazloum
        • Sep 2012
        • 499
        • Lebanon
        Yes the adapter is original
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            on page 98 there is the power sequence, it could be useful, look at pag 96 also
            the signals are very well described
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Check pin 15 85 120 64 SIO
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Check RTC_RST# at G1901 located near cpu.Check D2501. Moreoften then not, this mb doesnt switches on coz of RTC circuit failure while evrything seems ok. That may not be the case here but do check them. RSM_RST present on SIO??
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  There is no dc jack light on this model.
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Naṉṟi
                    • mazloum
                      • Sep 2012
                      • 499
                      • Lebanon
                      q1901 has 3.118v on drain and 0v on S and G.
                      d2501 is good
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        d2501 is good
                        test SIO chip page 23 pin 15 85 120 64 afte test U3601 page 35 pin 13 8 resistance to GND
                        • Luaina
                          • Sep 2016
                          • 12
                          • Madagascar
                          the laptop is dead:
                          no power:
                          After going down, Is the voltage on power button (PWRSW or NBSWON) pulled up to 3.3v as it should be?
                          • dileep.soft
                            • Nov 2009
                            • 6
                            i am facing exact proble No voltages at D2501 s-d-g 0v only
                            • voodoop
                              • Jul 2019
                              • 20
                              • Romania
                              I have a dead one , too .
                              I have 3V at D2501 .
                              • mon2
                                • Dec 2019
                                • 14259
                                1) Voltage on pin # 1, 2 and 3 of D2501 ?
                                2) Voltage on R2502 - both pins ?
                                3) Remove all power and check the resistance to ground on each and every coil. Searching for very low resistance on the respective power rail. Some CPU / GPU rails will be low resistance and that is normal.
                                  DELL Inspiron 3542 Notebook 3000 Specification for Upgrade or Repair
                                  This specification for the DELL Inspiron 3542 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3542 boardview and 3542 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3542...
                                  09-06-2024, 08:00 AM
