zed air sa power batton problem
  • karimreza2
    • Mar 2018
    • 23
    • Bangladesh
    my zed air as power batton in keyboard but on the keyboard power batton is brocken. so any body help how can i use secoundry power batton
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: zed air sa power batton problem
    Search on the keyboard connector the pin that corresponds to the power button, connect a cable and a button to this pin (the button must always be off and when it is pressed it must return from on to off) which sends the power on signal to ground .
    • karimreza2
      • Mar 2018
      • 23
      • Bangladesh
      sir, i search many times but i didnt found power botton pin on keyboard. please tell me number of pin.
      thanks
      • karimreza2
        • Mar 2018
        • 23
        • Bangladesh
        thanks
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Have you a schematic or boardview ?
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            With a multimeter try to find a pin with 3.3v , short it with ground only for <second (time) and see if the laptop go on
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Most likely pin2 of kbd connector is power switch but not sure.
              • karimreza2
                • Mar 2018
                • 23
                • Bangladesh
                There have no pin 3.3 volt. Without keyboard how can i make a powerbutton and from where 3.3 v connect to Groun. Please help
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  find a ground to the keyboard connector connect the 3.3v and ground power switch button
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    The safest thing to do is find out a schematic with same kbc(if not avlbl for this model) and find out the switching pin and then trace continuity between that kbc pin to kbd connector. If 3v avlbl there, then just connect a wire on that pin and touch the other end of the wire to gnd point on the mb to turn it on.
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • Duranitron
                      Asus x512dk rev 2.1 power on problem
                      by Duranitron
                      When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                      Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                      11-26-2024, 10:22 PM
                    • EazyBone
                      LG OLED55C9PUA power problem
                      by EazyBone
                      Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                      Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                      I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                      The power supply to t con is different story.
                      This...
                      06-23-2023, 07:43 AM
                    • Dr.d
                      Help please..Lenovo ideapad 5 14itl05 power and charging problem
                      by Dr.d
                      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                      04-05-2024, 11:48 AM
                      03-31-2024, 02:12 PM
