how to repair a WD sata HDD?
  • erdos
    • Jul 2012
    • 14
    hi, i was given a problematic 1TB Western digital Sata HDD for laptop recently.
    the disk has read error, i wasn't able to read from the disk.
    the person who passed the disk to me is in the business of selling laptops, he said it's possible to
    fix it by replacing the circuit board, i was wondering how true this is? and i'm curious how complicated is to fix the hdd.
    maybe the storage part of the hdd is good, just control logic or spinner went bad?
    specs:
    1TB WD10SPZX WD Blue (EIDE)
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: how to repair a WD sata HDD?
    Read error is either dying heads/head preamp or bad sectors on the surface.
    Anything that's not the PCB itself cannot be fixed. If it's for data recovery, send it to a data recovery company without attempting anything. Usually data can be recovered with the correct tools and experience, but the hard drive cannot be restored to its original state.
    Also just replacing the PCB itself won't work, you at least have to swap the ROM between the PCB. But that will not solve any issue related to read/write error.
    • erdos
      • Jul 2012
      • 14
      thanks for the reply!
      • DynaxSC
        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
        by DynaxSC
        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
        The behaviour is also really very strange, i.e.:
        • The disk shows always up in BIOS - so it is recognized, so far so good
        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
        02-23-2025, 01:33 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
        HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
        This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
        09-12-2024, 03:28 PM
      • clabr
        Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
        by clabr
        Need help to solve some problems with this laptop.
        After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
        After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
        Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
        Before this had happened I observed some other problems:
        When I tried replacing original mecanical HDD with a SSD HDD could not get them...
        12-02-2021, 08:09 AM
      • welp
        PS5 Disk Tray issues.
        by welp
        I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
        Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
        Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
        So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
        With that knowledge I preceded to check all the fuses for the 12v rail on the main...
        12-19-2024, 02:04 PM
