EC bios flash error with CH341A
  • NOoFEARoNL
    • Jan 2015
    • 13
    • netherlands
    Hello all
    I got a serious problem i try to flash ec bios from a Acer Travelmate 5744
    model bic50
    I did everything they way it should be but with writing to the chip i get message Write operations timeout failed ( look at picture)
    i write with a CH341A pro programmer .
    he also not accept the backup bin i made i got the same error
    I hope somebody has a solution big thanks infront
    • 21936
    Re: EC bios flash error with CH341A
    You chose the wrong bios chip. The 5744 has a 4MB bios.
    • piernov
      • Jan 2016
      • 4439
      • France
      He's trying to flash the EC SPI ROM, which is a 1Mb chip.
      • NOoFEARoNL
        • Jan 2015
        • 13
        • netherlands
        Yes thats right i already did the 4 mb chip that went okay but the ec chip doesnt want to be writen i did a read and back up but when i wanne write it it give the error
        i dont think it wil work with a blank ec chip
        if somebody knows the solution i wil be thankfull
          • 21936
          Yes my mistake ,"flash ec bios" . It seems the chip faulty and needs replacing with a new one.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Yeh agree with smdflea. If 4mb bios writes perfectly then nothing is wrong-so has to be ec bios chip itself
            • NOoFEARoNL
              • Jan 2015
              • 13
              • netherlands
              thanks for the help i first did an install of another version of the software but it gives now the message acces violation at adres 0097ea42 read of adres 0099ea42 so this time he try to read the chip
              better try a new chip
              thanks for the fast reaction
              • abbhas
                • Sep 2021
                • India
                Originally posted by NOoFEARoNL
                Hello all
                model bic50
                im getting the same error check the image if any one got resolution please let me know
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3628
                  • slovakia
                  mostly it is badly soldered contact on ic or chip is 1.8V
                  • yuviuv46
                    • Aug 2022
                    • 11
                    • India
                    Thats right.If the chip pins are not soldered properly onto the programmer you will be getting this error.
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Hi use
                      Neoprogrammer or colibri much better support more chips .
                      Regards Steve
                      • hahndyto
                        • Jun 2022
                        • depok
                        Originally posted by Stevedb
                        Hi use
                        Regards Steve
                        Thanks a lot, its working..
                        • sajidmirza
                          • Aug 2021
                          • 24
                          • india
                          Hi use
                          Regards Steve
                          you are amazing
                          worked like a charm
                          colibri
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • what_1282105
                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                            by what_1282105
                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                            02-14-2025, 07:27 PM
                          • abhorsen
                            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                            by abhorsen
                            Hey guys,
                            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                            07-06-2023, 10:22 AM
                          • AkaBukai
                            Is it okay to flash stock bios onto the motherboard's BIOS?
                            by AkaBukai
                            Hi there,
                            I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                            The little LED on the power button is flashing slowly and nothing happen.
                            This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                            So I decided to flash the BIOS using a cheap programmer.
                            And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                            I also...
                            12-19-2024, 12:15 PM
                          • James Jackson
                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                            by James Jackson
                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                            05-01-2025, 11:28 AM
