Lenovo cg410/cg510 nm-a681 3.3v area short
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    Lenovo cg410/cg510 nm-a681 motherboard no power on.
    It pu200 ic burn - now 3.3v area short, heating processor
    how to fix this error
  • karlox
    • Dec 2017
    • 131
    • México
    Re: Lenovo cg410/cg510 nm-a681 3.3v area short
    Well, I would start by cleaning with caution. You have a short to the graphic card. So then you have to work with the team diagram. Review integrated and see if they are short, they are not always the problem, measure resistances according to the schematic. The unfortunate thing would be that the graphic is damaged.
    • karlox
      • Dec 2017
      • 131
      • México
      There you have the schematic.
      https://www.badcaps.net/forum/attach...5&d=1507829541
      • Sanjeewait
        • Aug 2016
        • 63
        • Sri Lanka
        I'm removed core coil but same error. M/B Have a NVIDIA DEDICATED graphic.
        Can you show the error area diagram?
        • karlox
          • Dec 2017
          • 131
          • México
          Yes, well it comes with two graphics chips one is the nvidia and the other is the integrated CPU. What you should check are the connection rails to the CPU to be discarding components. In the picture an IC is damaged, but I can not see its number. Send a better picture or the position number of the components that you see in damage!
          • piernov
            • Jan 2016
            • 4436
            • France
            Dead PCH.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes indeed pch is gone but i doubt the pins are not separated properly on the burnt side of ic. It appears so from the pic. If ground is in contact with other nearby pins of IC-that can be the reason of high consumption shown in bench psu. So re check once the burnt pins with schematic.
              • DynaxSC
                Extreme High Current & Low Voltage Short Killer ??
                by DynaxSC
                Hi Folks
                I'm looking for a extreme high current short killer solution for a reasonable cost.
                I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                After taking off the socket, the shorts dissappear again.
                The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                10-15-2024, 10:13 AM
              • Stephen
                MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                by Stephen
                I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                02-06-2025, 12:03 PM
              • toty79
                Lenovo B50-50 (80S2) No display no Post
                by toty79
                Hello friends and welcome back,sorry for my English but I'm in Italy and I'm using a google to translate
                Main board CG410/CG510 NM-A681 rev 1.0
                I have this Lenovo laptop under repair with strange behavior, no display at first I thought it has a corrupt bios but now after disassembling it I have doubts, the laptop turns on automatically after inserting the charger without pressing the power button, If I hold down the power button for 8 seconds, it turns off for 1 second but turns on immediately after 1 second, so you can't even turn it off, tested with and without RAM,...
                02-17-2024, 03:11 PM
                ALIENWARE Area-51 R2 i7-6900K Specification for Upgrade or Repair
                This specification for the ALIENWARE Area-51 R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R2 boardview and Area-51 R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                09-12-2024, 03:28 PM
                ALIENWARE Area-51 R4 i7-7800X Specification for Upgrade or Repair
                This specification for the ALIENWARE Area-51 R4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R4 boardview and Area-51 R4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
