Usb port not working on bios acer 4730z jal90 la-4201p rev 1.0
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    hi, i have this problem the laptop has a broken keyboard so icant used the internal keyboard so iwant to use a external keyboard but when I tried to plug the keyboard it wont function i tried different keyboard and mouse also but no chance , I want to know where to troubleshoot first?
    I also tried flashing its bios but no chance ,
  • karlox
    • Dec 2017
    • 138
    • México
    Re: Usb port not working on bios acer 4730z jal90 la-4201p rev 1.0
    Why do you want to reprogram the bios? First make sure you have voltage in the usb ports, sure you have some damaged coil. Just make sure that your input peripherals are good in another computer.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      [QUOTE=karlox;903093]Why do you want to reprogram the bios? First make sure you have voltage in the usb ports, sure you have some damaged coil. Just make sure that your input peripherals are good in anot
      whe i tried to measure the voltages its 5v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        5V is usb power. What about the other 2 pins-D+ & D- ??
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          I already figure it out looking to the back of the usb port I see a corrosion that may be the problem then I replace the all port now its already up and running .
          Thamnks fort the gereat help
          • EbrahimSiami
            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
            by EbrahimSiami
            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
            **What I have tried so far:**
            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
            07-02-2025, 02:31 PM
          • Wg188
            ACER Veriton Z4660G AIO bios help
            by Wg188
            I have an Acer veriton Z4660G all in one pc,
            Model: Z4660G-I5850H1 (VZ4660G_W)
            Need bios dump and schematic would save my life !
            to make a long story short I bought this all in one used
            with a broken lcd, with the objective of making a custom desktop out of it
            ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
            06-17-2023, 02:20 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • James194zt
            Acer Nitro 50-640E Corrupted BIOS Dump
            by James194zt
            My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
            All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
            04-28-2025, 03:29 PM
          • ub6ib969
            Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
            by ub6ib969
            Model Number: PO3-650
            Part Number: DG.BK4AA.006
            Serial Number : 33400117730
            BIOS IC : XM25QH256C
            I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
            07-02-2025, 03:51 PM
