can someone help me on this SVOD3 after i update the software to 1.0.7.3 and show need to update firmware, when i click updte firmware it show write error at then show update false. when i plugged it back again now the software cannot detect my svod 3. can someoine knows how to fix this please need it help badly
svod 3 cannot detect after failed firmware update
Tags: None
Re: svod 3 cannot detect after failed firmware update
already contacted the supplier gave an email of svod group but not responding. anynone who encountered this problem please helpComment
http://forum.svod-project.com/viewto...acd11a6b83c9b0
Nothing much in there from the Admin other than a graphic. But I'd say short pins 22 to 26, then connect via USB to PC. This likely put's it into a mode to restore the bootloader. Run SVOD software and select Update Firmware.Comment
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by rumpumpel1Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?10-24-2024, 08:59 AM
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
by piernovInfineon TPM firmware update files:
Infineon_firmware_update.zip
...Code:TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
Channel: BIOS Requests ONLY!
10-25-2025, 10:09 AM -
by pp74Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
Regards-
- Loading...
