Old Nokia DC connector dimensions?
  • Behemot
    • 4845
    • CZ
    What's the actual size of the charging connector on the old phones like 33x0? Appears to be something like 3.5x0.7 mm. Anybody knows the exact size? Do some shops have those tips?
    • 21932
    Re: Old Nokia DC connector dimensions?
    3.5mm on the old 3310 .
    https://www.ebay.co.uk/itm/Modern-Un...K/323244902888
    • Behemot
      • 4845
      • CZ
      I see no usable information or anything under that link.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Nokia seems to have multiple small barrel connectors for power. The one I have uses the really small one, like 2mm.
        Surprisingly wikipedia has some information: https://en.wikipedia.org/wiki/Coaxial_power_connector
        • Behemot
          • 4845
          • CZ
          Yeah the tiny one is used for newer phones, mostly the cheap ones with color displays. The 3,5mm on the other hand was used in 90s and early 2000s for all the monochrome models.
          Interesting, would not expect that on wiki Seems to be the one with 0.9 inside. Now where the heck to get that? Mouser has some 1.0mm but their prices are somewhat insane.
            • 21932
            I guess you didn`t see the last picture,it lists the nokia phone models for the 3.5mm and 2mm jacks.
            here`s some info about the 2mm jack,Check pages 18 and 19 https://cdn.badcaps-static.com/pdfs/...2abc66373c.pdf
            • Behemot
              • 4845
              • CZ
              No dimensions there!
              I wasn't asking 'bout the 2mm connector, was I?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                I wish I found that document about the 2mm charger almost a decade ago...I destroyed the PMIC of a phone because of it!
                Now I wonder if I should try to solder a new PMIC...
                • Tomylee
                  No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                  by Tomylee
                  Sorry for the person who’s going to read all this !
                  I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                  While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                  During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                  07-11-2025, 11:52 AM
                • 5mall5nail5
                  Help identifying connector for ASUS 4090 Strix RGB LED connector
                  by 5mall5nail5
                  Hi All -
                  I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                  Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                  05-04-2025, 07:47 AM
                  Nokia C2-01 RM-721 RM-722 Phone Schematic
                  The Nokia C2-01 RM-721 RM-722 was a mobile phone produced by Nokia. The Nokia C2-01 supported 3G and had a 3.2 megapixel back camera. It had a single SIM card. The handset was introduced to the markets in 2011. It replaced its predecessor, the Nokia 2700 classic and Nokia 2730 classic and has improved specifications....
                  11-05-2024, 07:40 AM
                • bussincaps
                  MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                  by bussincaps
                  Hello All,
                  tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                  Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                  eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                  Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                  I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                  08-03-2023, 12:57 PM
                • michhak
                  Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                  by michhak
                  Hi guys,
                  i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                  It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                  11-17-2021, 05:45 AM
