Ch341a programmer problem
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    25Q64FW BIOS CHIP i alredy back-up the bios file but when i try to flash it using it back-up it says Chip with the contents are in disagreement now the board is dead. How can i fix this type of problem?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    Re: Ch341a programmer problem
    did u read datasheet of that bios ic?
    it is 1,8V chip. u need a 1.8V adapter
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      now its running fine thanks again i only used the adapater
      • sasalli
        by sasalli
        Hi to all!
        i have ch341a programmer. iam trying to program MX25L6475EM2I-10G chip with 16mb file, bu the programmer software(v1.18) says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''. What should i do? Thanks!
        06-15-2022, 10:09 AM
      • what_1282105
        Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
        by what_1282105
        Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
        02-14-2025, 07:27 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • dj-bobr
        Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
        by dj-bobr
        I kindly ask for help with Thinkpad BIOS/ME repair.
        Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
        It worked fine until I tried to remove whitelist.
        Steps taken:
        - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
        - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
        03-05-2024, 04:28 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
