Need Acer 4750G DIS to UMA?
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    I need DIS to UMA on Acer 4750G,
    It has display on external monitor but White Screen on Display in Internal.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Need Acer 4750G DIS to UMA?
    did u try to reball?
    did u measure voltages on lvds connector?
    • ronelex
      • Oct 2016
      • 195
      • Philippines
      3.3v is present, bl is ok, not yet reballed
      • piernov
        • Jan 2016
        • 4439
        • France
        White screen means the display doesn't get power. Did you make sure it's not a cable or panel issue first?
        • maralexbar
          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
          by maralexbar
          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
          If anyone knows how to force the external monitor as primary for Notebooks of those models
          11-02-2024, 09:18 AM
        • DqMagetz
          Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
          by DqMagetz
          Good day!
          I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
          Here are the voltage readings:
          • Input – 19V (stable)
          • +LCDVDD – 3.3V briefly, then drops to 0V
          • EDP_HPD – 3.3V briefly, then drops to 0V
          • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
          • EC BKOFF# – 1.8V briefly, then drops to 0V
          • PANEL_OD_EN – 0.3V
          Is it possible that the EC chip is corrupted or damag...
          07-12-2025, 09:37 PM
        • ArchangelGabriel
          Aorus 17G YD laptop, broken display, could not switch to external monitor
          by ArchangelGabriel
          Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
          11-23-2023, 03:55 AM
          by momaka
          03-15-2023, 10:17 PM
          09-06-2024, 05:27 AM
