Apple 820-3115 b not posting - shorted cpu?
  • justin35
    • Jan 2019
    • 149
    • It
    I don't know the history of the board... it does look clean, i couldn't find anything then paper towel resitues on a few places...
    The board has fan spin
    It deeps without ram stick
    Pch and cpu get a little too hot...
    Measured ppvcore_s0_axg and i get 0.8 Ohms...
    On any other board i get 15+ ohms
    So i assume is shorted. I took out R7550 to see on which side is the short and is on the cpu side...
    also i did power the board without r7550 and a saw a little flas on the mouse diode, so it tried to post but went off.
    There are a few caps on that rail on cpu side, and i want to think one is bad and not the cpu...
    If i inject 1v @ 0.5 to 1amp on that rail will it fry anything else on that rail?
    I know ppvcore_s0_axg is ment to be present only if the internal display is connected, right?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Apple 820-3115 b not posting - shorted cpu?
    Yep you're right.
    Apparently VCore is not shorted and you have 0.8 ohms on VCCAXG, so I'd say that the CPU itself is not shorted but rather some component on the VCCAXG line.
    You can inject 1v, but don't go higher (maybe one or two hundreds millivolts more max) as you may risk killing the CPU.
    No real need to limit current there, it will probably not dissipate much power to begin with so the short may not become apparent right away.
    • justin35
      • Jan 2019
      • 149
      • It
      Well...bad news for me
      At 1v it takes 0.3-0.4 amps and nothing is getting warm...
      At 1.3v it takes 1.1amps and cpu starts to heat on the axg side...
      It looks like the cpu is bad
      • justin35
        • Jan 2019
        • 149
        • It
        Is it possible to have spinning fan if missing all_sys_pwrgd? (Different board but i don’t want to open a new thread yet)
        Ty!
        • justin35
          • Jan 2019
          • 149
          • It
          Anyone?!? Thanks!!
          • justin35
            • Jan 2019
            • 149
            • It
            Well i can confirm the cpu axg side was shorted...
            pulled out cpu short is gone
            Measured cpu axg pins to gnd ang get 0.8ohms to 1.5ohms...
            Another donor (
            • justin35
              • Jan 2019
              • 149
              • It
              Sorry for reviving this post, but my problem is related...
              Maybe some of you know and can help me understand something...
              I have multiple 3115 boards that have cpu axg line measuring arround 2 ohms...
              All of them are not working by some other faults But i wonder if it worh the effort to fix them and realize the cpu is “shorted”
              The questions is:
              What is the lowest ohm value measured on cpu axg and the cpu still works?
              I only have one working 3115 board and it measures 8.1ohms
              Thanks!!!!
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                With multimeter in diode mode, you read 000 ?
                • justin35
                  • Jan 2019
                  • 149
                  • It
                  In diode mode reding 0.001
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    I don't know the exact figures but above 2 ohms isn't alarming. Exact figure will depends on board, CPU model, temperature and may even vary from board to board.
                    Usually Ivy Bridges have pretty low resistance to ground compared to other generations.
                    • justin35
                      • Jan 2019
                      • 149
                      • It
                      Thanks again piernov!!!
                      You are right! I’ve gor my hands on a 3115 board 2.5 i5 which works and measured cpu acg and it was 2.2ohms !!!
                      • mkdj
                        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                        by mkdj
                        Dear all,
                        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                        Both N-Channel Mosfets: nothing odd
                        P-Channel MOSFET number 1:
                        source - drain : 117 kOhm
                        source - gate: 96 Ohm
                        gate - drain: 117 kOhm
                        P-Channel MOSFET...
                        08-20-2025, 06:08 AM
                      • barry101
                        Apple 820-3662 VCore shorted to ground.
                        by barry101
                        Hi, Would appreciate some help.
                        I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                        Get charger light but no fan spin or chime. No liquid damage.
                        Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                        Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                        With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                        Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                        06-24-2025, 07:34 AM
                      • mkdj
                        Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
                        by mkdj
                        Dear all,
                        Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
                        I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
                        I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
                        08-11-2025, 04:55 AM
                      • guizmo1967
                        Dell Latitude 5501 LA-H181P shorted power rail
                        by guizmo1967
                        This is my problem:
                        Laptop: Dell Latitude 5501
                        Motherboard: EDC51 LA-H181P
                        I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                        I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                        I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                        I injected +1.05V - 2A...
                        07-25-2023, 06:56 PM
                      • mferna14
                        Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                        by mferna14
                        Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                        06-25-2025, 11:26 AM
