Hello. Have this Lenovo g50-30 NM-A311 that came with burning U901 NCP CPU/GPU power ic. after replace, everything works, but with start button dont have CPU/GPU voltage. i have VR_ON signal, VCC voltages but no output/GATE voltages and i found one gpu highside mosfet burned. CPU/GPU have good resistance
					lenovo G50-30 UMA no CPU/GPU voltage after burned CPU/GPU power ic
	Tags: None
 Re: lenovo G50-30 UMA no CPU/GPU voltage after burned CPU/GPU power ic
 this lenovo freaks me out.
 i replaced NPC CPU/GPU power driver. now i have all powers, but after power button, it goe right to 2.25W and stay there. no video, only system led. try to relash bios, but still the same
 What's the voltage on CPU VCore? Check CPU reset signal.
 Chances are the CPU is dead though.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
 Cpu is at 0.73V and GPU at 0.8V
 PMC_PLTRST# is 1.8VComment
			by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
 Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
 https://www.ebay.com/itm/116497313155?var=416785404161
 Here are some of the description from the eBay seller
 The main parameters:
 1. Product name: High-power non-isolated DC boost module power supply.
 2. Product model: 100A2000W.
 3. Input voltage: DC12V-60V.
 4. Input current: 100A (maximum)....
			by PantherDaveHi all!
 Assuming...7 Photos
			by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
			by Dr.dI have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
 Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
- Loading...
