Epson projector problem Model Epson eb- s31
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    I'm having problem with display on this projector. There are vertical lines on display. I've opened it and cleaned it, cables are all clean and not broken. This model has 3 separate cables for blue,green and red.
    Does anyone knows about the cause of the problem or solution. I dont have much experience in projectors
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Epson projector problem Model Epson eb- s31
    Pic of problem
      • 21968
      I found some info on epson https://www.epson.co.uk/viewcon/corp...faq/5275/16249
      You may need one of the calibration sheets to adjust it, i don`t know if it can be adjusted without it .
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Thanks smdflea for replying but its not a scanner. How do i calibrate it. i have checked all the settings in menu and even reset all but in vain.
        as per some information on net, it is connectivity issue between logic board and lens unit(In this case it is through 3 different cables viz red,blue,green, -all of which seems to be ok.
          • 21968
          Yes its not a scanner what was i thinking, i shouldn`t post when tired
          Have you tried updating the firmware .
          https://www.epson.co.uk/products/pro...-s31#downloads
          • mmartell
            • Oct 2013
            • 3189
            Maybe try unhooking the flex Cable for the green LCD and see if the lines go away ? It looks more like a processing failure to me though...
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              yes, firmware update didnt solved it. I tried unhooking cables one at a time and the vertical lines go away when blue cable is dis-connected. Are those spares available?? Its relatively a new model.
              • mmartell
                • Oct 2013
                • 3189
                Probably would have to harvest one from a broken projector. All three should be identical as they are monochromatic anyway. The real problem is they are aligned at the factory so replacing it is only the start of the battle.
                Besides you would need to be sure the LCD is at fault first. Maybe it is displaying exactly what it is told to display and the fault is farther upstream ?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Thanks for replying. I know it is very difficult to align them resulting in shadowy image if not matched perfectly. I dont have similar cable with me. So gave up on this and returned to customer.
                  • tubesky
                    • Sep 2016
                    • 4
                    • Davao oriental
                    Sir try To use another optical engine...possible problem is the Optical engine,
                    • fmajbour
                      Acer Nitro 5 model A515-51 keyboard problem
                      by fmajbour
                      I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                      Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                      i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                      I have check the keyboard connector on the mainboard every thing looks ok.
                      Then i replaced the keyboard with new one ......same problem exact same keys problem.
                      I need your advice if anyone face...
                      11-13-2023, 09:50 PM
                      HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                      This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 05:27 AM
                      HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                      This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                      This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    • narf
                      Epson EB-U42 projector / Caps with 0.7 ohms ?!
                      by narf
                      hi all,
                      first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                      i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                      what i've found so far:
                      - the PSU does its job and supplies 12V to the mainboard via the connector.
                      - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                      - not far away, there's the first cap with a resistance of 0.7 ohms....
                      07-02-2024, 03:53 PM
