asus k56cm missing resistor
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Hi, HDMI hot plug pin 19 HDMI connector: This pin if I understand well send a signal to a transistor gate to flow a tension from 3VS to pch . The signal on pin 19 HDMI is not direct but is managed by two resistor.
    In asus g73 there are two resistors but I don't understand the function of D4802 and how the motherboard manage the hot plug signal, probably from GPU
    I
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: asus k56cm missing resistor
    On G73JW, I think D4802 is only acting as a clamping diode. Seems like the HDMI port is driven by the MXM video card only.
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Ok,
      but on k56cm can I use 1 K resistor ?
      Pin 19 on HDMI connector is an output signal, right ?
      • BlueMidnight
        • Jan 2015
        • 489
        Yes, on the G73JW, D4802 clamps voltages that are less than ground (negative) or higher than 3V.
        The monitor provides 5V on pin 19 so the board knows when a monitor exists. The larger resistor to ground (10K on the K56CM) makes sure the pin is not left floating (or else it may trigger a false detection). And the smaller series resistor being 1/10 of that value (i.e. 1K) should be just fine. The resistance can't be too much higher than that, or the transistor will never turn on
        The transistor is used to convert the 5V signal to a 3V signal for the the rest of the board (PCH and EC).
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          I have used a 1k resistor and now the mosfet reach the treshold voltage and send +3VS voltage to PCH, but the hdmi don't work.
          I have repaired this motherboard after another technician fails ; I don't know what he did but it seems that he changed the hdmi port. I checked all pins and all seems ok but there are two resistors:
          R4821 (HDMI_CLK_C -> HDMI_CLK_R) in place
          R4822 (HDMI_DAT_C -> HDMI_DAT_R) missing
          I think that R4822 is required because I don't see any connection for this data line.
          Unfortunately, the boardview is in .ASC format and it is not known whether a component must be placed or its value, based on R4821 I think that R4822 must be the same.
          • BlueMidnight
            • Jan 2015
            • 489
            Yes, both resistors are required, and there is no reason why they wouldn't be the same value.
            • on/off
              • Oct 2016
              • 333
              • Indonesia
              Hope this helps.
              This my interpret by base from Asus N73SV, but need confirm from BlueMidnight and Piernov is correct or not.
              Actually on page 23 and 48 only.
              Red rectangle mark on schematic is part from your BV K56CM.
              Sadly on HD image K56CM R4821 and R4822 covered by black tape.
              Link HD image:
              https://drive.google.com/drive/folde...EU1WVlKWmtJQnM
              Credit to [tsurik] Nikolay Tsurka
              • EnricoS92
                • Sep 2018
                • 26
                • Italia
                I have a K56cm, both resistors are present (under the black tape under the heatpipe) and they are 0 ohm.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  Thanks All for the support
                  I replace the missing resistor with 0 ohm and the hdmi works great-
                  • gurj1979
                    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                    by gurj1979
                    Hey guys.
                    Need help with this one.
                    Fan not spinning due to missing PWN Fan signal.
                    Also 5 seconds from powering up it freezes, unless in BIOS.
                    But as soon as Windows starts to load, it will freeze.
                    CPU is COLD / Room temp when it freezes.
                    I've replaced the CPU, same problem.
                    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                    Replaced fan - same problem.
                    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                    08-19-2024, 05:22 PM
                  • ShadowAi
                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                    by ShadowAi
                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                    03-15-2024, 10:46 AM
                  • Slang
                    Asus RTX 2060 Evo Missing resistor
                    by Slang
                    Hi
                    i need to know value of the circled resistor on the back side of the card.
                    TIA
                    Slang...
                    02-25-2024, 07:53 PM
                  • Chewy6288
                    Asus FA506QE missing MOSFET
                    by Chewy6288
                    I recently bought this laptop to try to fix up because it was so cheap. It has no power so I figured it was a MOSFET or cap issue so I started with taking it apart, but when I had it apart I noticed one of the MOSFETs was missing. I'm new to this so I don't know where or how to look up what to replace it with. I do have the boardview for it so I somewhat know what was there which I attached ,and the missing piece is PQ303....
                    07-30-2025, 07:24 AM
                  • khabib
                    ASUS STRIX G531GT MISSING PM_SLP_SUS#
                    by khabib
                    Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
                    here what i measure already:
                    EC_RST# 3.3V
                    SRTCRST# 3v
                    +3VA_RTC 3V
                    RTCRST# 3V
                    ME_SusPwrDnAck 0V
                    AC_PRESENT 3.3 V
                    AC_IN_OC# 0V
                    PS_ON 3,3V
                    +3VA_DSW 3.3V
                    DPWROK_EC /R 3.2V
                    PM_BATLOW# 3.3V
                    SM_INTRUDER# 2.8V
                    PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
                    THat is can confirm PCH relate issue...
                    05-28-2024, 01:30 AM
