Inspiron 3437 won't turn on
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Inspiron 3437 won't turn on
    OK good news check pin 104 & 14 KBC24 PCH_PWROK / S5_ENABLE as you press the power buttton
    TPS51125 pin7 ?
    • piernov
      • Jan 2016
      • 4435
      • France
      Check RTCRST#, SRTCRST#, INTVRMEN, INTRUDER#, DSWVRMEN, DPWROK and 32kHz RTC clock going to the PCH.
      EDIT: S5_ENABLE is present because all rails of the 3V/5V regulator are present. PCH_PWROK comes up way later in the power sequence (in S0 state).
      • Techtiger
        • Oct 2014
        • 1602
        • france
        ok thanks piernov Just saw it page 99 of the Schematic
        • infoplus
          • Aug 2017
          • 83
          • ALGERIA
          RTCRST# 3.2v
          SRTC_RST# 3.2v
          INTRUDER 2.8v
          INTVRMEN ?
          DSWVRMEN 3v
          DPWROK 2.8v
          32kHz RTC clock yes
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Originally posted by infoplus
            RTCRST# 3.2v
            SRTC_RST# 3.2v
            INTRUDER 2.8v
            INTVRMEN ?
            DSWVRMEN 3v
            DPWROK 2.8v
            32kHz RTC clock yes
            infoplus
            i saw i a diffrent forums same MOB same prob as your's change the Q2402 and U3601 it might work for you it' sort of a hit & RUN solution
            • infoplus
              • Aug 2017
              • 83
              • ALGERIA
              #26
              Originally posted by techtiger
              infoplus
              thanks bro
              finally when i removed u3601 i noticed that i have a short in 3D3V_S0 line
              motherboard turn on without u3601
              • Techtiger
                • Oct 2014
                • 1602
                • france
                #27
                Great Bro so my hit & RUN SOLUTION Worked happy to hire
                • mohammed aram
                  • Apr 2015
                  • 73
                  • egypt
                  #28
                  this is great
                  • infoplus
                    • Aug 2017
                    • 83
                    • ALGERIA
                    #29
                    Thank you gays for you support you are the best
                    • smali
                      • Sep 2014
                      • 287
                      • Pakistan
                      #30
                      welldone @techtiger
                      • infoplus
                        • Aug 2017
                        • 83
                        • ALGERIA
                        #31
                        hello every one please help me with this motherboard https://www.badcaps.net/forum/showthread.php?t=73243
                        • Naineesh1
                          DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
                          by Naineesh1
                          I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
                          Schematic diagram : bios chip volt...
                          07-05-2025, 01:20 AM
                        • trunguntilyou
                          Inspiron 5406 If the device only plugs in the battery, the device will not turn on
                          by trunguntilyou
                          Most of my devices cannot turn on with the battery (sometimes they still turn on). When I plug in the charger or both, it turns on normally. When I plug in the battery, it turns on and has 3v, 5v, 1.8v, (when each battery is not turned on, there will not be these 3 sources). In addition, there is no power even though Anyway, now I just need to plug in the charger, and the device will automatically turn on and turn on normally
                          st H0ZTM93
                          19860-1
                          Link to boardview/schematic - https://www.badcaps.net/forum/showthread.php?t=119432
                          Reminder: rules and organization...
                          10-22-2023, 10:51 PM
                          DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 03:44 PM
                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
