Inspiron 3437 won't turn on
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Hello
    Ihave a laptopInspiron 3437 won't turn on with or without battery.
    doe40-hsw gddr5 mb 12307-2
    i have listed voltage present:
    19v
    3.3/5v
    power btn: 3.3v
    Where is the problem exactely... please help me
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Inspiron 3437 won't turn on
    Did you try to flash with a woking Bios ?
    Voltage in PU4501
    pin 3 6 13 20
    PL4503 PL4502 Voltage ?
    KBC24 pin 20 Voltage ?
    • infoplus
      • Aug 2017
      • 83
      • ALGERIA
      Voltage in PU4501
      pin 3 6 13 20
      YES I flash the bios not working
      this i have an other schematic for my board
      any way
      TPS51125
      PIN3 3.3V
      PIN6 3.3V
      PIN13 5V
      PIN20 3.3
      PL4503 3.3V
      PL4502 5V
      PIN20 IO 3.3V
      • Techtiger
        • Oct 2014
        • 1602
        • france
        KBC 117 pin voltage PM_PWRBTN ? & test RTCRST_ON
        • mohammed aram
          • Apr 2015
          • 74
          • egypt
          measure X1901 pin 1 & pin 4
          you must get Frequency 32.768 hz or Value nearby this with oscilloscope
          • mohammed aram
            • Apr 2015
            • 74
            • egypt
            make sure about these signal
            PM_RSMRST#
            AC_PRESENT
            • smali
              • Sep 2014
              • 287
              • Pakistan
              is it battery charging ok?
              • infoplus
                • Aug 2017
                • 83
                • ALGERIA
                all ok
                • infoplus
                  • Aug 2017
                  • 83
                  • ALGERIA
                  PM_RSMRST#
                  AC_PRESENT
                  pin 20 PM_RSMRST# 3.3v
                  pin 112 AC_PRESEN 0v
                  • infoplus
                    • Aug 2017
                    • 83
                    • ALGERIA
                    yes charging ok
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      Check S_SLP_S4# and S_SLP_S3# when pressing/releasing power button
                      • smali
                        • Sep 2014
                        • 287
                        • Pakistan
                        first you check KBC_PWRBTN 3.3v droping towords 0v by pressing power button on apower botten connector and also check on KBC pin#93.
                        then check the genration of PM_RSMRST on pin#20 and also check PM_PWRBTN on pin#117...if all these are ok then you have problem in your PCH which is combinde with cpu....
                        • infoplus
                          • Aug 2017
                          • 83
                          • ALGERIA
                          slp s3 & s4 0v
                          • infoplus
                            • Aug 2017
                            • 83
                            • ALGERIA
                            KBC_PWRBTN 3.3v droping to 0v
                            PM_RSMRST 3.3v pefore pressing power button????
                            • smali
                              • Sep 2014
                              • 287
                              • Pakistan
                              RSMRST will be genarate after the press of power Btn
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                Originally posted by infoplus
                                slp s3 & s4 0v
                                PCH wake up SIGNEL from SIO IS not responding try to slight heat up the CPU AND SEE
                                CAN SOME ONE TELL IF THE SIO pin 112 AC_PRESEN IS 0V IF THE CAUSE TO PCH NOT RESPOND?
                                • infoplus
                                  • Aug 2017
                                  • 83
                                  • ALGERIA
                                  ok thanks
                                  • piernov
                                    • Jan 2016
                                    • 4439
                                    • France
                                    SLP_SUS# and BATLOW# present?
                                    SLP_S4# spiking when plugging AC adapter in or pressing power button?
                                    Missing ACPRESENT should not prevent PCH going out from S5, but missing BATLOW# will. However, maybe there's something wrong with the EC if ACPRESENT is missing.
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      Thanks Piernov
                                      • infoplus
                                        • Aug 2017
                                        • 83
                                        • ALGERIA
                                        last time i tested Pin 112 Wich is Ac present i got 0v but now when yesterday i heat up PCH i got 3.3v Ac present
                                        PM_SLP_SUS 0.23v
                                        BATLOW 3.3v
                                        slp s3 s4 0v when pressing power btn
                                        • Naineesh1
                                          DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
                                          by Naineesh1
                                          I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
                                          Schematic diagram : bios chip volt...
                                          07-05-2025, 01:20 AM
                                        • trunguntilyou
                                          Inspiron 5406 If the device only plugs in the battery, the device will not turn on
                                          by trunguntilyou
                                          Most of my devices cannot turn on with the battery (sometimes they still turn on). When I plug in the charger or both, it turns on normally. When I plug in the battery, it turns on and has 3v, 5v, 1.8v, (when each battery is not turned on, there will not be these 3 sources). In addition, there is no power even though Anyway, now I just need to plug in the charger, and the device will automatically turn on and turn on normally
                                          st H0ZTM93
                                          19860-1
                                          Link to boardview/schematic - https://www.badcaps.net/forum/showthread.php?t=119432
                                          Reminder: rules and organization...
                                          10-22-2023, 10:51 PM
                                          DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
