Inspiron 3437 won't turn on
    Re: Inspiron 3437 won't turn on
    OK good news check pin 104 & 14 KBC24 PCH_PWROK / S5_ENABLE as you press the power buttton
    TPS51125 pin7 ?
      Check RTCRST#, SRTCRST#, INTVRMEN, INTRUDER#, DSWVRMEN, DPWROK and 32kHz RTC clock going to the PCH.
      EDIT: S5_ENABLE is present because all rails of the 3V/5V regulator are present. PCH_PWROK comes up way later in the power sequence (in S0 state).
        ok thanks piernov Just saw it page 99 of the Schematic
          RTCRST# 3.2v
          SRTC_RST# 3.2v
          INTRUDER 2.8v
          INTVRMEN ?
          DSWVRMEN 3v
          DPWROK 2.8v
          32kHz RTC clock yes
            Originally posted by infoplus View Post
            RTCRST# 3.2v
            SRTC_RST# 3.2v
            INTRUDER 2.8v
            INTVRMEN ?
            DSWVRMEN 3v
            DPWROK 2.8v
            32kHz RTC clock yes
            infoplus
            i saw i a diffrent forums same MOB same prob as your's change the Q2402 and U3601 it might work for you it' sort of a hit & RUN solution
              Originally posted by techtiger View Post
              infoplus
              thanks bro
              finally when i removed u3601 i noticed that i have a short in 3D3V_S0 line
              motherboard turn on without u3601
                Great Bro so my hit & RUN SOLUTION Worked happy to hire
                  this is great
                    Thank you gays for you support you are the best
                      welldone @techtiger
                        hello every one please help me with this motherboard https://www.badcaps.net/forum/showthread.php?t=73243
