Lenovo L420 no power only led battery blink 3 times
  • lepak06
    • Feb 2017
    • 51
    • france
    I ve 2 Lenovo L420 with no power only led battery blink 3 times when plug charger
    I check voltage on motherboard.
    I found 3VPCU and 5VPCU
    I found 5V_S5 (few second after press power button) , 3VSUS (always),3V_S5(always)
    BIOS IC i found 3,3V only after press button few second.
    I tried flash bios
    Didnt find voltage of CPU, of DDR, ...
    thx
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo L420 no power only led battery blink 3 times
    (BIOS IC i found 3,3V only after press button few second)
    you should get 3.3V on pin 3 and 8 with out pressing the power button
    voltages on all colis Pl15 Pl12 ect
    • lepak06
      • Feb 2017
      • 51
      • france
      No 3,3V on Bios ic U9600 without press power button
      but on the bios IC 512ko U21 i found 3,3V on pin 3 and pin 8
      Voltage only on coil PL19 PL20
      All the other coil are 0V with press button and without press power button
      • Techtiger
        • Oct 2014
        • 1602
        • france
        page 42 U37 PCH Bios chip flash this bios chip 4MB with this bios
        https://www.badcaps.net/forum/showth...ht=Lenovo+L420
        dod you get 3.3V in power button ?
        (there is no Bios ic U9600)
        • lepak06
          • Feb 2017
          • 51
          • france
          when i read the U9006 i found a similary dump.
          The U9006 is an 25Q32 winbond. I didn't find on motherboard U37 at te page 42.
          i ve 3,3v at the power button.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            ok Schematic you have upload is for L412 not for L420 near the PCH you have another bios chip send close up snaps of the MOB both sides
            test you power button when you press it goes to 0V
            • lepak06
              • Feb 2017
              • 51
              • france
              The motherboard is DAGC9EMB8E0 rev:e, i found only the L412 schematic
              When i press power button the voltage from 3.3v to 0V
              • Techtiger
                • Oct 2014
                • 1602
                • france
                remove that part
                • lepak06
                  • Feb 2017
                  • 51
                  • france
                  I checked voltage of KBC IC but i didn't find the 3V at C134
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    since i don't have the Schematic i cannot tell you exact KBC number if it's IT8502E you have to test pin 26 50 92 114 121 any of the pin have 3.3V KBC power ok but in KBC a lot of test point's to check. You have programmer U21 512ko? Tell me the number 2en BIOS chip
                    • lepak06
                      • Feb 2017
                      • 51
                      • france
                      I flashed the 2 bios ic. always the same problem
                      The 2th Bios ic 25q32 (4M) and the other is 25x40 (512k)
                      I'll check the kbc voltage.
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        now check if your bios working one if the KBC number is
                        IT8502E
                        pin 33 RSMRST
                        pin 20 ECPWROK
                        pin 125 NBSWON take the measurements as you press the power button
                        • dspok
                          • Jan 2014
                          • 553
                          • Nepal
                          did you solve this problem?
                          I have same issue in L440 model.
                          • OKRPKCOMP
                            • Dec 2020
                            • 439
                            • PAKISTAN
                            I have also same problem in this model
                            Anybody have solved this problem????
                            • somnath
                              • Dec 2022
                              • india
                              rtc section is short. In my case C8364 is shorted.
