Lenovo L430 won't turn on
  • Smilo_
    • Sep 2014
    • 20
    • FRance
    Hello
    I plugged a L430 which I didn't use for 4 months. And it doesn't want to power up.
    I tried another charger, replace RAM, clear cmos, whitout hard drive and nothing.
    When I plug it in the startup button comes green fix, battery led is orange fix without battery inside and mute sound button comes orange fix after the fan starts spinning 1 sec.
    When i tried without ram the fan spin but no beep song. I don't know if there are beep song on this laptop.
    Do you have an idea please?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Lenovo L430 won't turn on
    Dissemble the laptop come up with Voltage measurement for example PL4301 PL4302 big gray coils you have to measure all the coils
    Try with a external screen does your caps lock key key board working
    • Smilo_
      • Sep 2014
      • 20
      • FRance
      I measured Pl4301 et pl4302. I got 1.2V for 2seconds then 0V when I plugged the charger
      PL4101 3.36V
      PL4103 5.02V
      PL1 2.72V
      PL4601 I got 1.55V for 2seconds then 0V when I plugged the charger
      PL4401 0V
      PL4501 I got 1.04V for 2seconds then 0V when I plugged the charger
      No display with external screen, and caps lock key key not working.
      • Techtiger
        • Oct 2014
        • 1601
        • france
        (Pl4301 et pl4302. I got 1.2V for 2seconds then 0V when I plugged the charger
        PL4401 0V
        PL4501 I got 1.04V for 2seconds then 0V when I plugged the charger)
        Voltage should be stable not 0V what is your output voltage of the charger?
        Page 39 BATT1 pin 1234 voltage with battery in?
        Measure voltage with charger without battery and remove the charger only with the battery all the coils
        PL4301
        PL4302
        PL4401
        PL4501
        PL4601
        PL4701
        PL4801
        • Smilo_
          • Sep 2014
          • 20
          • FRance
          I said something wrong about the measures I had done.
          I measured all voltage with the charger plugged without battery (dead). What I wanted to say is for Pl4301,pl4302, PL4601 and PL4501 I got voltage for 2 seconds and after 0V. I had to plug/unplug for this 4 coils to get Voltage.
          I can't turn off the laptop with the power button. I plug it in, it starts to on. The startup button comes green fix, battery led is orange fix without battery inside and mute sound button comes orange fix after the fan starts spinning 1 sec. Then those 3 leds still in this condition and i can't turn the laptop off, I have to unplug it.
          I will do what you ask asap.
          The output voltage of my charger is 20V
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • melvinvdb
            Lenovo y520-15ikbm most of the time doesn't turn on
            by melvinvdb
            I've repaired a few laptops in my life but this time my own laptop died😂.
            Funny enough this one is a bit tough on me.
            It doesn't turn on (most of the time).
            Model: Lenovo y520-15ikbm (NM-391).
            The only way to make it turn on is:
            1) unplug battery + charger + rtc (seems irrelevant)
            2) wait a minute
            3) plug battery/charger in
            4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
            5) when it turns on it also displays POST...
            08-15-2024, 12:28 PM
          • g1150
            Lenovo G565 Laptop , LCD not turn on, external terminak ok.
            by g1150
            Lenovo G565 Laptop onboard LCD Display does not turn on.
            Only works with external Monitor.
            I am trying to verify that the LCD signals from the motherboard are ok.
            The LCD was working, but over time happened to not turn on more frequently.
            Now dead.
            Possibly the cable from MB to LCD is broken somewhere.
            I just wonder how it is detected if external or internal monitor shall be activated ?
            I found the following schematic on the net:
            Problem 2:
            The graphics chip ATI Mobility Radeon HD5470 seems defective.
            On Win7...
            05-07-2025, 11:51 AM
          • dqtech
            lenovo x240 nm-a091 wont turn on
            by dqtech
            i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
            board number VIUX1 NM-A091 REV:1.0...
            02-07-2024, 01:57 AM
          • Patriarxis
            Lenovo IdeaPad 3 14ADA05 dosen't turn on
            by Patriarxis
            Hello.
            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
            It takes 0.027A and the power button flashing.
            All the voltages on the board are ok. 3.3, 5 etc.
            Also is charging the buttery .
            What else i can check?​
            05-26-2025, 01:03 AM
