ASUS X555LD Rev. 3.1 no power on CPU
  • Conste
    • Oct 2018
    • 235
    Hello again,
    The next board I purchased to make my F 555 work again.
    Board starts immediately after I plug charger inside, GPU gets warm, but CPU not.
    No screen.
    I guess CPU doesn't get supply voltage, no voltage on PL8003, the big inductor to deliver CPU voltage.
    +3VA_EC, 5V etc. are all there.
    Which points shall I measure?
    Measuring resistance to ground is hard because of very low CPU voltage...
    Thanks in advance.
  • Conste
    • Oct 2018
    • 235
    Re: ASUS X555LD Rev. 3.1 no power on CPU
    CPU phase seems to be shorted to ground, I try removing components...
    CPU voltage regulator seems to shut down because of short
    • Conste
      • Oct 2018
      • 235
      Removed PCE8001, problem persists. So this was not a faulty cap
      PLE8003 removed, no voltage on both sides -> PU8000 dead?
      Resistance to ground on PIN2 still less than 1 Ohm, on a working board the resistance is 9 ohms, so there has to be a short somewhere in the CPU_VCC circuit? Or is the CPU dead?
      Should I apply CPU supply voltage (1,7V) to the circuit and see which component gets warm?
      CORE_PWRGD is not present
      ALL_SYSTEM_PWRGD is present.
