Hi All ,
I got this laptop and the seller said that it gives no screen image.There was no power adapter with it.
I checked it and sure enough there was a dead short on some mosfets.
I replaced about 6 mosfets and it seems that the short has gone.Now when I plug in the power adapter , the white and the amber led in the power jack lit up (just for about 1 second) and then go off.
At the same time the fan spins also for about 1 second and the the white led on the power button board comes on and stays ON.
When I press the power button , 1st time nothing happens.I can press 2 or 3 times and then it seems that the system is starting.The CPU - GPU etc get warm and there is about 1.5 Amp of current.
I supect that the GPU is defective so I will need to replace it.
But the lights in the power jack must stay ON , yes ???
I have all the voltages (will check if there is 3 V at the power button).
Sometimes the system starts all by itself , so a little more work to do ...
The fan output was clogged so I guess it got too hot inside.But is that a reason to let 6 mosfets die ??
