HP G4-1015DX cmos problem
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need help on this how to solve this problem on HP g4-1015dx BOARD IDA0R22MB6D0 REV. the problem is i need to removed and insert the cmos battery in order the laptop to start. because once it shutdown i need to removed cmos first before it boots fine.someone please help me on this
  • Romy2018
    • Sep 2018
    • 174
    • japan
    Re: HP G4-1015DX cmos problem
    anyone need help please
    • Romy2018
      • Sep 2018
      • 174
      • japan
      anyone please help on this i need to removed and insert the cmos battery in order the laptop to boot fine. please help on this please
        • 21984
        Schematic: http://www.s-manuals.com/motherboard/quanta_r22
        Check the CMOS battery voltage. On page 12 of schematic, check all caps ,resistors,diodes on +AVBAT .Check Y3 xtal .
        • Romy2018
          • Sep 2018
          • 174
          • japan
          thanks for the schematic smdflea, i back again here at first i change only cmos it works but now the problem came back and still the same issue need to removed cmos and plugged in in order to boot the laptop fine, so i did some measurements based on you advise and schematics, here it is on page 12 R269 measured 1.1k and has 3v when cmos is plugged in but 0.5v when cmos removed. the same on D21 both side have 3.v if cmos is plugged in but if pulled out only one has 3v the other side 0.5v only.but D22 both have 3v even cmos plugged in or out.any advise and help please
          • Romy2018
            • Sep 2018
            • 174
            • japan
            need help on this please
              • 21984
              Test C673 and C675 for short ,if ok change Y3 xtal .
              • Romy2018
                • Sep 2018
                • 174
                • japan
                i cannot find the Y3 C673 and C675 located.could you help me please
                  • 21984
                  I just noticed that you have a revision D board .There`s a boardview available for it, but i don`t have it.Its on the paid sites .
                  • Romy2018
                    • Sep 2018
                    • 174
                    • japan
                    maybe someone can share on this board view please i could not find the Y3 c673 and c675 located on the board
                    • Romy2018
                      • Sep 2018
                      • 174
                      • japan
                      Need help please
                      • Romy2018
                        • Sep 2018
                        • 174
                        • japan
                        need help please
                        • Romy2018
                          • Sep 2018
                          • 174
                          • japan
                          still i cannot find the location of this C673 C675 and y3 could anyone help me on this please
                            • 21984
                            I found the rev D boardview .
                            • ganeshcell
                              • Jan 2014
                              • 80
                              • india
                              i think flashing bios can solve ur problem
                              backup old and flash bios
                              • Romy2018
                                • Sep 2018
                                • 174
                                • japan
                                @smdflea i cannot open the file because it is .bdv @ganeshcell already done flashing the bios but still the same issue
                                  • 21984
                                  https://openboardview.org/
                                  • ganeshcell
                                    • Jan 2014
                                    • 80
                                    • india
                                    try this software
                                    • ganeshcell
                                      • Jan 2014
                                      • 80
                                      • india
                                      try this
                                      • theone111
                                        by theone111
                                        3. Problem: TV shuts down
                                        07-22-2024, 10:36 AM
                                      • dj-bobr
                                        Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
                                        by dj-bobr
                                        I kindly ask for help with Thinkpad BIOS/ME repair.
                                        Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
                                        It worked fine until I tried to remove whitelist.
                                        Steps taken:
                                        - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
                                        - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
                                        03-05-2024, 04:28 AM
                                      • Zeonalbasta
                                        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                        by Zeonalbasta
                                        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                        09-13-2024, 01:17 PM
                                      • HTR-Informatique
                                        by HTR-Informatique
                                        02-09-2025, 06:51 AM
                                      • Gibon378
                                        Problem with stopping audio and video for no reason
                                        by Gibon378
                                        PC Specs:
                                        • CPU: Ryzen 5 1600
                                        • GPU: GTX 1080 Palit JetStream
                                        • MOBO: ASRock ab350 PRO4
                                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                        • PSU: XFX 650W (don't remember what model)
                                        • OS SSD: ADATA SP920
                                        • OS: Windows 10 21H2
                                        Problem description:
                                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                        11-19-2022, 09:41 AM
