pls i need guide to fix this toshiba c850 with no back light plz assist
toshiba c850 back light problem
Re: toshiba c850 back light problem
Is schematic available?? M/B code?? If avlbl, then post the schematic here and do the basic homework like measuring voltage on lvds pins and report here. -
this is the schmatics mateAttached FilesComment
Refer to page 34 of schematic and check voltage on pin 21/22/23/24/25 & Pin 1/2/3/4/5 and post here if you are not willing to measure all pins.Comment
I doubt your measurements. Pin 1 &2 are connected together and can be 19V but pin4 cant be 19v. Are you aware how the pins are numbered on lvds connector-Its not serialwise. Pin1 on this side and pin2 on the opposite other side. Re check once again.Comment
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by boyebaranhi to all
tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
please advise me tnx4 Photos05-20-2025, 07:11 AM -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
