Imac 21,5" Motherboard 820-2641-A
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi
    I've a problems with this kind motherboard. Only the first green led is on, but if i press the power switch nothing happen.
    No short on the board, and correct tension on the power switch (3.3 V)
    Any suggestion?
    Luca
  • ryogadan78
    iMac A1311 - Motherboard 820-3126-A, turn on sometimes
    by ryogadan78
    Hi guys, I have this 2011 iMac A1311 with a strange problem.
    Most of the time, when I plug in the power cord, the first of the 4 LED's turn on, but when I press the power switch the LED turns off and iMac won't boot up.
    Sometimes, when I unplug and plug the power cord back in, iMac starts up correctly by turning on the 4 LEDs in sequence.
    I have already tried a new power supply, but the result does not change. Do you have any suggestions?
    Motherboard 820-3126-A​
    04-06-2024, 05:19 AM
  • glovecaps
    by glovecaps
    11-25-2024, 04:23 PM
  • Docus
    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
    by Docus
    Hi everyone 😀,
    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
    1. I already own the exact same model, but its plastic chassis is badly damaged.
    06-10-2025, 04:24 PM
  • jasobrino
    trying to repair imac motherboard model A1311 (late 2009)
    by jasobrino
    Some time ago I acquired an imac computer model A1311 that does not boot (motherboard ref. 820-2494-A).
    The power supply is working properly (I have two), it delivers the 12V on pin 4 of the power connector (PP12V_S5).
    As I have the schematic diagram and the boardview, I have made a series of measurements, obtaining the following results:
    PP12V_S5 -> 12V
    3V3REG_VCC -> 3.12V (something low?)
    PP5V_S5_LDO -> 0.02V
    3V3REG_VCC -> 0.0066V
    I have also measured the resistance to ground on the coils, and I can't find...
    02-20-2024, 11:48 AM
  • Archimedes
    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
    by Archimedes
    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
    Fans are spinning. Blindly could install windows11 and got the device manager...
    07-30-2024, 05:14 PM
