ACER Z1402 on around 10 second and off
  • BlueRay
    • Jul 2018
    • 20
    • Indonesia
    Checked 19v, 3v, 5v, 10.5v, etc seem ok. i found one problem on switch button has 9.55v.
    Try change Q7 and Q57 ic. but problem still exist, any suggestion? does the problem come from EC controller ic?
  • gilasenak
    • Nov 2009
    • 15
    • Malaysia
    Re: ACER Z1402 on around 10 second and off
    Have you solve the problem? Mine also have the same ptoblem.
    • qonma
      Kuli Solder
      • Jun 2017
      • 185
      • INDONESIA
      same problem too
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        can you please tell us the original problem..so that we can relate.. and what have you done so far...any schematics for this unit..
        Never stop LEARNING because life never stops TEACHING!
          • 21984
          The schematic is already posted - https://www.badcaps.net/forum/showth...ighlight=Z1402
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            ok did you check the on of switch? if the switch is open you get 3.3v if its close you get 0v
            • bigbily09
              • 68
              • qc
              Did you solve the problem. I got mine same problem 9v on power switch
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                https://www.badcaps.net/forum/attach...3&d=1537151559
                check all the mosfets.. switch must be 3.3v when open and 0v when closed..
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  9V sounds ok there.
                  • lapfix
                    • Mar 2020
                    • 2765
                    • my workshop
                    9V is ok like piernov say : resistor divider .
                    Check Q7 , R174
                    • samsung35
                      • Jul 2020
                      • Philippines
                      check 19v power rail is present or maybe shorted and check the 3.3v and 5v are present if present all if the problem is not exist put the thermal paste and clean the fan if dirty thank u hope u help my suggestion
                      • SACR
                        • Jul 2019
                        • 30
                        • Malaysia
                        Anyone solve this problem?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3628
                          • slovakia
                          post your voltage readings(VIN, 3/5VALW, powerswitch)
                          • SACR
                            • Jul 2019
                            • 30
                            • Malaysia
                            Thanks reply. My problem same like this...
                            • Orsolino
                              • Nov 2020
                              • Phillippines
                              What is the problm if PWM_IN 3.3v is drop going to 0vdin the picture of screen is problm also.?
                              • Han404
                                • Aug 2019
                                • 4
                                • Indonesia
                                i found problem same too
                                • lazybigyan
                                  • Mar 2017
                                  • 81
                                  • Nepal
                                  Everybody has same problem with mine too. Any suggestion or solution do you have? Wait for any response. Thank you.
                                  • vienzen
                                    • Feb 2015
                                    • 112
                                    • PHILIPPINES
                                    Anyone who solve this problem? any suggestion?
                                    • lazybigyan
                                      • Mar 2017
                                      • 81
                                      • Nepal
                                      Did you gays check the y2 (32.7khz)? Not done but not any improvement from change y2. So any further movement.
