Lenovo G50-80 No power on (no led) (ACLU3/ACLU4 UMA NM-A362)
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Re: Lenovo G50-80 No power on (no led) (ACLU3/ACLU4 UMA NM-A362)
    i disconnect every time for measure resistence
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      so these voltages are fine. now check resistance on PL710 and PQ302 relative to GND.
      I think it is time to replace a new PQ304 now.
      • robgerr
        • Apr 2012
        • 70
        • Italy
        I'm trying to understand the mainboard screen printing but pl710 is not present, but I have pl709 anywhay resistence pl709 6 Mohm
        PQ302 pin 1,2,3 392kohm
        pin 4 158kohm
        pin 5,6,7,8 go up 20 Mohm
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          that is right. It is time to replace a new PQ304 now before you change any other component. after the replacement, measure voltages on pins of PQ302. Find a good replacement for PQ304.
          • robgerr
            • Apr 2012
            • 70
            • Italy
            Replaced PQ304 from other mainboard (DTA144EUA).
            Same problem.
            Measure on PQ304:
            pin 1 18,40v
            pin 2 19,80V
            pin 3 20,01
            measure PQ302:
            pin 1,2,3 19,77v
            pin 4 19,95V
            pin 5,6,7,8 1,80v
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              #26
              so we have made no great progress yet. now remove PQ302 and measure voltages on PQ304.
              • robgerr
                • Apr 2012
                • 70
                • Italy
                #27
                PQ302 removed.
                Voltage PQ304:
                pin 1 19,7V
                pin 2 19,9V
                pin 3 20,1 v
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  #28
                  now that PQ302 is removed, try to replace PQ302 by a new one which you know is healthy.
                  • robgerr
                    • Apr 2012
                    • 70
                    • Italy
                    #29
                    ok, now I see to find it. I was doubtful if the problem could depend on an charger IC
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      #30
                      yes, it is possible. ACOK should be high but it is zero. to check it, measure voltages on pins 5,6,12,16,19,20 of PU301.
                      • robgerr
                        • Apr 2012
                        • 70
                        • Italy
                        #31
                        Replaced for safe pq301 and reflow zone with flux and laptop start normally. Testing...
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          #32
                          bq24737 ACOK is active low so this is fine. The issue really seems to be at the voltage divider PR303/PR307.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            #33
                            does it charge the battery now?
