Lenovo G50-80 No power on (no led) (ACLU3/ACLU4 UMA NM-A362)
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Good afternoon forum. This laptop has the following defect: It does not turn on, no LEDs, it does not charge the battery. Dismantling the board on the bench, I checked and did not exit B + from PQ302.
    On the source I find 19,80V
    On the drain 0.90V
    On the gate 19.20V.
    I tried to remove the mosfet and jumper drain and source and the machine turns on perfectly,
    Not having SI4483 I tried to replace it with AO4407 but nothing.
    Another thing I noticed but I do not know if it can help, on the power connector, ADAPTER_ID is at 0v
    I think the flaw starts from the bad pilot signal of pq302 in the gate
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Lenovo G50-80 No power on (no led) (ACLU3/ACLU4 UMA NM-A362)
    what voltages are on the three pins of pq302 after the replacement by AO4407?
    • robgerr
      • Apr 2012
      • 70
      • Italy
      Same of old mosfet
      • robgerr
        • Apr 2012
        • 70
        • Italy
        try to replace with ao433 but nothing.
        voltage pin 1,2,3 20,2v
        voltage pin 4 (gate) 18,4v
        voltage pin 5,6,7,8 0,91v
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          I think the gate voltage should be lower. thus, check voltages on PQ304 and PQ307B and PQ998A.
          • robgerr
            • Apr 2012
            • 70
            • Italy
            pq304:
            pin 1 19,9v
            pin 2 20,1v
            pin 3 18,6v
            pq307:
            pin 1 0v
            pin 2 3,20v
            pin 3 0v
            pin 4 0v
            pin 5 3v
            pin 6 0v
            PQ998
            pin 1 0v
            pin 2 0v
            pin 3 3,34v
            pin 4 0v
            pin 5 0v
            pin 6 3,30v
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              they seem fine. now, check voltages on PQ990.
              edit: I think you exchanged voltages of pin1 and pin3 of pq304 by mistake.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                In addition, check resistance between pin1 and pin4 of PQ302.
                • robgerr
                  • Apr 2012
                  • 70
                  • Italy
                  PQ990:
                  pin 1 0v
                  pin 2 0v
                  pin 3 0v
                  pin 4 0v
                  pin 5 0v
                  pin 6 19,03 v
                  pPQ302:
                  res pin 1-4 195kohm
                  sorry for pq304 but i think this pin out:
                  http://pinout.net/transistors/B.gif
                  is correct?
                  anywhay pin 1 19,42v
                  pin 2 19,78v
                  pin 3 19,59v
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    At this point, there is no clue to find the faulty component. Now as a try, you can remove PQ304, then start the laptop. If it started normally, probably PQ304 is faulty. Otherwise, if there was no voltage at the drain of PQ302, resolder PQ304 at its place on the mainboard. I hope this method work, because finding the faulty component gets really difficult then.
                    • robgerr
                      • Apr 2012
                      • 70
                      • Italy
                      Thank you. then I removed pq304 is the laptop had turned on. I connected the battery to test the charging, the orange led started to flash. I think he was starting to charge the battery. After ten minutes I find all the LEDs off, I try to turn on and nothing again, I try to remove the battery and try again with adapter but nothing. What I understand is starting to be difficult to repair quwsta mainboard. Do you have any other ideas?
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Check voltage on PQ302 and PQ307 again. Maybe when you removed PQ304 something heated up and that temporarily fixed the issue.
                        • robgerr
                          • Apr 2012
                          • 70
                          • Italy
                          pq302 same value
                          pq307:
                          pin 1 0v
                          pin 2 2,92v
                          pin 3 0v
                          pin 4 0v
                          pin 5 3,03v
                          pin 6 0v
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            It seems like you're exactly in the same situation as before, but with PQ304 removed right?
                            Check resistance across PC308.
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              the battery should not be connected. However, I think no severe damage is made to the mainboard. At least, you discovered that pq304 has to be replaced later.
                              • robgerr
                                • Apr 2012
                                • 70
                                • Italy
                                yes.
                                checked pc308, no shorted
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  the value of resistance across pc308 is important. please mention it. In addition, check all the points near PQ302 and PQ304 for being shorted or having a voltage other than your previous measurements.
                                  • robgerr
                                    • Apr 2012
                                    • 70
                                    • Italy
                                    sorry, 198kohm
                                    if I invert the tips, 130kohm
                                    • caspian
                                      • Oct 2015
                                      • 1591
                                      • Laptop
                                      disconnect power every time you connect it to the mainboard in this situation. now continue Post17.
                                      • robgerr
                                        • Apr 2012
                                        • 70
                                        • Italy
                                        checked PQ998, same value
                                        checked pq304 pads (ic removed):
                                        pin 1 0v
                                        pin 2 19,80v
                                        pin 3 20,2v
