Asus ROG G750JZ
  • TheNikdo
    • Aug 2018
    • 19
    • Czech Repuplic
    Re: Asus ROG G750JZ
    On the 4 mosfet pins theres 0.5v and if i disconect charger it goes slowly down to 0.
    Same with the pin on DC board.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      Re: Asus ROG G750JZ
      the green mark on dc board shouldnt go to 0 volt (with charger connected and dc board disconnected from mainboard). that pin should have 19volt.
      • TheNikdo
        • Aug 2018
        • 19
        • Czech Repuplic
        Re: Asus ROG G750JZ
        When i have DC board disconected from motherboard i can read 19v on that pin but if i plug the DC board into motherboard its 3.88v
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          Re: Asus ROG G750JZ
          when u have 3.88 volt, some component get hot on mainboard ? check those 2 mosfet or other parts of mainboard if something get hot.
          • TheNikdo
            • Aug 2018
            • 19
            • Czech Repuplic
            Re: Asus ROG G750JZ
            No atleast not on touch and i dont have thermal camera so i cant look ,but i wanna ask is it safe to asume that its the motherboard problem i am thinking about ordering motherboard and have this one for learning/spare parts etc...
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              #26
              Re: Asus ROG G750JZ
              pch (northbridge ) either is not getting hot ?
              not sure if its still a bad dc board that maybe has some problem....
              • TheNikdo
                • Aug 2018
                • 19
                • Czech Repuplic
                #27
                Re: Asus ROG G750JZ
                Well everything sems cold i touched like every mosfet,cap,Ic,cpu.
                  • 20863
                  Re: Asus ROG G750JZ
                  Theres a boardview for a G750JW here,it has the same DC-IN jack ,and similar layout.
                  https://www.badcaps.net/forum/showthread.php?t=63471
                  • TheNikdo
                    • Aug 2018
                    • 19
                    • Czech Repuplic
                    #29
                    Re: Asus ROG G750JZ
                    Thx ill try to look where the problem might be.
                    • TheNikdo
                      • Aug 2018
                      • 19
                      • Czech Repuplic
                      #30
                      Re: Asus ROG G750JZ
                      So i just found out that if i measure from charger to conected dc-in board i get the 19v so in the end it rly might be the dc -in board somehow shorting ?
                      edit:same with the back when measuring from charger not dc-in board or motherboard ground.
                      • cacla
                        • Apr 2015
                        • 442
                        #31
                        Re: Asus ROG G750JZ
                        Replace the dc pin i have the same problem the other day.
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          #32
                          Re: Asus ROG G750JZ
                          use metal of vga connector or metal of usb port as ground and check if u have + 19v on that component marked red and green , or they say -19volt. i think all looks just fine except when u say that external psu connector has 19volt, while it should be the gnd that and 19v sould be in the inside of it.
                          • TheNikdo
                            • Aug 2018
                            • 19
                            • Czech Repuplic
                            #33
                            Re: Asus ROG G750JZ
                            Phew guys i ordered new dc-in board and ntb works flawlesly i think that dc-in board pcb was shorting somewhere in the pcb or something like that.
                            I would like to thank all the guys that tryed to help.
                            Thank you guys
                            • dellxps15
                              • Feb 2014
                              • 1588
                              • italy
                              #34
                              Re: Asus ROG G750JZ
                              congratulation for the fix man
