motherboard damaged near gpu
  • myth77
    • Feb 2017
    • 380
    • Croatia
    i have asus board that somebody damaged really hard with srewdriver near the gtx g960m gpu (the motherboard has two gpu cards)...Some lines/nets on the motherboard were cut very deep and long and some just on surface...For three longer cuts i made wire jumpers and solder everything...but for several others shorter cuts that (maybe only half milimeter) i applied solder only to fill the gap (i used no wire)...Now the board starts i get the picture..but whenever i tried to change to 960m gtx it starts very slowly..sometimes even black screen...
    So i am wondering is there a difference between a wire jumper and a solder only jumper for a smaller gaps between two lines on board? or there is something else i missed while trying to solder everything back?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5080
    • New Zealand
    Re: motherboard damaged near gpu
    Photos would be useful. Solder vs wire wouldn't be a problem, bridged traces is more likely.
    There may be damage to internal layers though, if the scratches are deep enough
    -David VanHorn
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • araxnido
      Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
      by araxnido
      Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
      When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
      06-10-2025, 09:26 PM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
