no power With Hp Dv 2000
  • moateez
    • Jun 2014
    • 119
    • algeria
    hi eveybody i need hekp with mu Dv2000 Not worck not turn at all
    when i plug dc cable bleu led worck on power jacket
    3.3 in power buton but not turn the fan
    ic power maxim8725e make 3.3 and 5 is Good
    need help please diagram
    Akita Mb
    48.4F501.051
    052331-5
    94V-0 GX D-V0A159G6100P
  • 65c102
    • Apr 2017
    • 28
    • england
    Re: no power With Hp Dv 2000
    try this
    • moateez
      • Jun 2014
      • 119
      • algeria
      Originally posted by 65c102
      try this
      Sorry This scematicsDont match with my matherboard
        • 22001
        Try this one: http://kythuatphancung.vn/download/h...chematics.html
        • moateez
          • Jun 2014
          • 119
          • algeria
          Originally posted by SMDFlea
          thnx Friend this is my shematici will reserche for the problme if you have time help me please
          • moateez
            • Jun 2014
            • 119
            • algeria
            Ithink the probleme is in Thsi Ic U40 Idont find it in mather oard it was removed befor the clinet brig the laptop to me
            he is in party of Run Power
            AAT4280IGU
            what is his equivalent
            • moateez
              • Jun 2014
              • 119
              • algeria
              Please Help With AAT4280IGU
              • moateez
                • Jun 2014
                • 119
                • algeria
                hello Frends Please Help
                  • 22001
                  Heres the datasheet
                  After a quick google search for a "sot23-6 Slew Rate Controlled Load Switch"
                  https://cdn.badcaps-static.com/pdfs/...7479e797a1.pdf
                  Compare the 2 parts, voltage,rds, slew rate. This looks like a good alternative SiP4280-1-T1-E3 .There`ll be more alternatives,you just have to search through datasheets.
                  • moateez
                    • Jun 2014
                    • 119
                    • algeria
                    Thnks brother iwill try and make reply
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
