pls. equivalent IC Audio realteK
  • karim011
    • Nov 2016
    • 117
    • Morocco
    Hi guys. pls i need equivalent IC Audio realteK ALC 861
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: pls. equivalent IC Audio realteK
    No equivalent, needs to be replaced with 861 only.
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • SoulFreeze
      Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
      by SoulFreeze
      Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
      After repairing the above issue, I realized the following remaining problem,
      Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
      The computer recognizes headphones are connected and displays a popup in windows
      Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
      06-21-2025, 09:53 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • FZG
      HP Stream 11 - Realtek Audio IC getting very hot
      by FZG
      Hi everyone! I have a problem with my HP Stream 11 Laptop (11-ak0023ng) yet again.
      Originally, a load switch on one of the USB ports had blown up and the laptop would not power up. The original post can be found here:
      https://www.badcaps.net/forum/showthread.php?t=121134
      I replaced that load switch with an original replacement part and the laptop starts up and works fine again except for one thing: when testing the device the sound was crackling badly and I noticed the Realtek ALC3247 sound chip was really hot (canΒ΄t touch for more than a second)....
      08-17-2023, 12:09 PM
    • i_am_patch
      Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
      by i_am_patch
      Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
      04-30-2024, 08:20 PM
