820-00165-02 missing PP3V3_S4SW_SNS rail
  • cj_002
    • Jul 2018
    • 8
    • Sweden
    Hey there,
    Prologue:
    I'm 4 days into component level repairs, still on my fist board an 820-00165-02 (coffee damage), no severe corrosion anywhere. I have (to the best of my knowledge) many of the "basic" rails present (see list below). However I'm failing at PP3V3_S4SW_SNS which is just showing 0,2 V (No short in diode-mode unplugged). According to schematics for 820-00165-A PP3V3_S4SW_SNS comes from U8050, however i´m missing the enable SMC_SENSOR_PWR_EN (no short in diode-mode unplugged).
    Question(s):
    1. As I'm following schematics for 820-00165-A what differences should i expect since i´m working on a 820-00165-02 board?
    2. Finally the most obvious: Why no SMC_SENSOR_PWR_EN/PP3V3_S4SW_SNS.
    Thankful for any help or tip.
    I have the following rails:
    PPBUS_G3H 8,6 V
    PPBUS_S5_HS_COMPUTING_ISNS 8,6 V
    PPBUS_S5_HS_OTHER_ISNS 8,6 V
    PPDCIN_G3H_ISOL 15 V
    PPDCIN_G3H 15 V
    PP3V42_G3H 3,42 V
    PPVRTC_G3H 3,33 V
    PP5V_S5 5 V
    PP5V_S4RS3 5 V
    PP5V_S0 5 V
    PP3V3_S5 3,3 V
    PP3V3_S4 OK 3,3 V
    PP3V3_SUS 3,3 V
    PP3V3_S3 OK 3,3 V
    PP3V3_S0 OK 3,3 V
    PP3V3_S4SW_SNS 0,2 V
    PP3V3_S0SW_SSD 3,3 V
    PP3V3_S4_TBTAPWR 3,3 V
    PP1V8_S3 1,8 V
    PP1V2_S3 1,2 V
    PP1V05_SUS 1,05 V
    PP1V5_S0 1,5 V
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-00165-02 missing PP3V3_S4SW_SNS rail
    You didn't go to the end of the power rails, especially PPVCC_S0_CPU, but this would look like the machine may turn on, even with a missing PP3V3_S4SW_SNS.
    Still, strange behaviour. Any liquid near the SMC, U8050 or Q5500? What's the resistance to ground of SMC_SENSOR_PWR_EN?
    Also check the voltages going into/out of U1950.
    • cj_002
      • Jul 2018
      • 8
      • Sweden
      Thank for your reply!
      Cant see much corrosion anywhere.
      Resistance: SMC_SENSOR_PWR_EN to ground = 600 ohms.
      Voltage U1950:
      pin1: 0,1 V
      Pin2: 3,3 V
      Pin3: 0 V
      Pin5: 0 V
      Pin6: 0 V
      Pin7: 0 V
      pin8: 3.42 V
      • cj_002
        • Jul 2018
        • 8
        • Sweden
        Also Vcore=0 V
        • piernov
          • Jan 2016
          • 4439
          • France
          With all the rails you have, ALL_SYS_PWRGD (pin 1 of U1950) should be high. If you feel like it you could check voltage on all pins of Q8150, and check voltage on R8164/R8165/R8166/R8167/R8168 but this is probably a dead end.
          SMC_SENSOR_PWR_EN being only 600 ohms to ground is too low in my opinion, but I don't have any board to check on. You could remove Q5500 and U8050, and see if the resistance goes up.
          But with weird measurements like that, it would point to an issue with the SMC. You may try to reflow it if you're confident.
          • cj_002
            • Jul 2018
            • 8
            • Sweden
            Unfortunately i don' t have this tools for that at the moment. However I just noticed that U7600 and U8080 gets really hot to the touch when i plug in charger, but i cant see how this could impact the 1.05 V rails as they come from the PP3v3_S4SW_SNS rail right?
              • 21863
              Why are U8080 and U7600 getting hot,and what do those IC`s have in common ? U8080 pin 2 P5VS0_EN .U7600 pin 16 P1V05S0_EN .
              Look at the S0 Enables rail ,page 59 on the schematic.Test voltage,ohms on U8180,R8180,C8185,C8186,C8187.
              • cj_002
                • Jul 2018
                • 8
                • Sweden
                Thanks for your input! On U8180 i have:
                Pin 1&2: 3 V
                Pin 5: 3.3 V
                Pin 4: 5 V (is this to high?)
                I also checked the resistors and caps you asked for: C8186= 4.98 V however I'm missing R8180, C8185 and C8187, it seems as if they were never placed on the board ill attach image:
                  • 21863
                  My bad,those parts are "no stuff" ,i must have been tired.... . What else does U8080 and U7600 have in common, U8080 pin 1 PP5V_S4RS3 ,U7600 pin 12 PP5V_S4RS3 . Check PP5V_S4RS3 voltage,check if its stable .
                  • cj_002
                    • Jul 2018
                    • 8
                    • Sweden
                    U8080 and U7600 both have enables from U8180. Since U8180´s output is 5V on both P5V_S0_EN (U8080) and P1VP5S0_EN (U7600) this might be why they get hot? U8180 being a logic gate should just output the 3,3 V from PP3V3_S5 right? However the board seems to be in S0 state since all S0 rails are present and stable except PPVCC_S0_CPU. Not sure how to proceed.
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                    • BC_TechForum_drb
                      Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                      by BC_TechForum_drb
                      Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                      Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                      Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                      2/ Figure 1 Gfx-D500-B Front Facing
                      3/ Figure 2 +5v supply (zoom-in)
                      Intro:
                      While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                      12-07-2023, 09:55 PM
                    • theflyingsquirrel
                      Samsung Chromebook Pro missing 1.2V power rail and no boot
                      by theflyingsquirrel
                      I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                      When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                      06-11-2025, 08:11 AM
                    • Grucha98
                      Zotac gtx 1060 3gb missing one rail
                      by Grucha98
                      Hello everyone, i have zotac gtx 1060 3gb, and it has missing one rail. I think its 1v but I'm not sure. This rail has 34 Ohms, but after test on on my testbench, it drops to 2ohm, after some time it back to 34 Ohms. Next to this coil is up1727q. And there are 3,3 on vin pin and 5v on vdd pin. I changed this chip with another one but it didnt help. When i tried Short circuit test, core didnt heat up so maybe its still alive. I dont have thermal camera :/. I dont have boardview and schemstic for this GPU too. What should i check next? Or maybe its just dead core?
                      04-11-2024, 08:09 AM
                    • noflux
                      Surface pro 5 (Model 1726) missing 3.3V power rail
                      by noflux
                      Hello All
                      Have a Surface pro 5. Main board model; M1007506-015. Main 15v power rail is present.
                      1st image;
                      Missing 8v rail at inductor (circled in blue). Suspect main cause is power is being drawn at dead short on C4517.
                      2nd image;
                      3.3v rail was measured at 0.17v (at top most capacitor with red cross in 1st image).
                      Capactors crossed out in red are shorted.
                      Are the 5v and 3.3V rails tied in somehow e.g. generated at a single IC?
                      2nd and 3rd image;
                      C4517 circled in red is shorted at pin...
                      06-18-2023, 03:45 PM
